NYC Drift King
06-20-2009, 05:59 PM
How do I fix this?????
http://i295.photobucket.com/albums/mm151/omarh121385/IMG_0009.jpg
http://i295.photobucket.com/albums/mm151/omarh121385/IMG_0013.jpg
expo1
06-20-2009, 06:08 PM
you either need a new oil cooling line or the cooler itself. If your still under warranty the dealer will take care of it. If not you will need to buy the part and replace it. Its not that big of a job. I would clean that up and see if you can tell where the leak is coming from.
chrism
06-20-2009, 06:14 PM
omar we can fix that in my garage.....but your buying the sand to dry the floor with......
dozer
06-20-2009, 06:22 PM
do it! and take pics :yesnod:, pics soon to come of "dozers driveway", 2 1/2 spring instals, a cold air intake install, and 2 power steering issues knocked out with in 2 weeks
NYC Drift King
06-20-2009, 06:25 PM
Chris are you available tomarrow?
NYC Drift King
06-20-2009, 06:27 PM
I have 62000 miles so im pretty out of warrenty =[
Helghast7
06-20-2009, 06:31 PM
you might be able to put some sealant on the bolt to prevent it from leaking, at least temporarily to stop it from leaking
04RX8man
06-20-2009, 08:20 PM
wipe it off and try to find exatly sure where it's leaking before i would do anything....
NYC Drift King
06-20-2009, 09:01 PM
it seems to be coming from the silver bolt.
chrism
06-20-2009, 09:05 PM
tomorrow is fathers day.....tina got me going over to her parents....you sure if its the line or the cooler?
NYC Drift King
06-20-2009, 10:15 PM
its a brand new cooler so I'm pretty sure its the line or bolt...
expo1
06-20-2009, 10:26 PM
New Cooler?? What's the story behind the new cooler?
Winning 8
06-20-2009, 11:40 PM
did you change the new cooler with new washer??
swoope
06-21-2009, 02:44 AM
new crush washers?
beers :beer:
nycgps
06-21-2009, 10:00 AM
yeah why did you buy a new cooler?
it seems that you installed it wrong. (or its not secured)
put some high temp RTV around the bolt should do the trick, make sure its the one that has high oil resistant and support up to 600F :)
04RX8man
06-21-2009, 12:56 PM
^agreed.....prob something u did when changing the cooler
dannobre
06-29-2009, 10:32 AM
Looks like its missing the inside crush gasket??
