methanol kit on a 6port
Old Jun 20, 2009 | 04:30 PM
TRU5hot's Avatar
Hey all maybe I havent looked hard enough for a thread of methanol kits. But I wanted to hear of preferable kits the the pros and cons. I have a 6spd Auto N/A does any have the same with the methanol setup. Thanks
Old Jun 21, 2009 | 12:12 PM
invasion08's Avatar
I have only read that methanol kits are used on FI cars to keep engines safer at the point where boost is introduced.
Old Jun 21, 2009 | 02:17 PM
chickenwafer's Avatar
Nope
The only point in adding a meth kit on an NA car is if you can tune for it. I would recommend getting the AP and then you can slowly advance timing since the Meth will basically give you race gas. You could pick up some impressive gains- not sure if anyone has tried it yet
Old Jun 21, 2009 | 06:54 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Yep, both of your are right. Tru5hot Meth/Alchy/ injection is really there as a means for charge cooling in a FI'd setup. one really shouldn't tune with it on in boost.
THink it as a safe guard.
Now If you intend to use it as charge cooling and a little extra power from the Meth, You would have to tune for it. however on the other hand NOS would be less hassle and more bang for the effort.
What were your ideas for the meth usage?
Old Jun 21, 2009 | 09:38 PM
TRU5hot's Avatar
Okay heres the deal I have all the basics done to my car. The car has amazing handling now that im running 9.5 wide front and back but the power needs a little help the SC kit looks like its gonna be way up there in price and Nitrous seems dangerous so i heard meth kits when in use can make you pretty much have racing fuel bump up the octane level. For the money that seems worht it and its not that bad for my car.
Old Jun 22, 2009 | 05:08 PM
Nope
The problem is stock timing is pretty aggressive as it is. You can't really advance it too much. Of course you can, but just how much is the question.
I agree nitrous will cost you only a hundred bucks more than a good water meth kit and much more bang for the buck. It's not dangerous unless you're Easy_E1 and blow intake manifolds LOL
Old Jun 23, 2009 | 12:23 PM
09Factor's Avatar
And most of those destroyed manifolds were caused by "R&D".
"R&D" being, what is a safe RPM/Load to spray at and then let off the gas.
Anwser. Something higher than 4.5k rpm.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
bosstin87
Oct 5, 2015 06:52 AM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
