Has anyone installed tie rod spacers on their 8 yet?
Old Jun 18, 2009 | 11:56 AM
iLikeEatPoo's Avatar
The Great Dick
I'm about to do an install and wondering is anyone has done it before and how satisfying the results were. If no one has done it I plan to make a write up with before and after pictures and steering angle increase results.
Old Jun 18, 2009 | 12:13 PM
Why?
Old Jun 18, 2009 | 12:15 PM
mike[piston eater]'s Avatar
O' Let's do it.
maybe for drifting?
Old Jun 18, 2009 | 12:21 PM
alnielsen's Avatar
Possibly correct the steering geometry on a lowered car?
Old Jun 18, 2009 | 12:27 PM
^ there is more than enough adjustment to get over 1/2" toe in/out...how much could you need
Old Jun 18, 2009 | 12:31 PM
alnielsen's Avatar
^Not toe. Moving the tierod up or down. I don't know, we haven't seen these yet.
Old Jun 18, 2009 | 05:13 PM
The Great Dick
The reason is I reach full lock way too quickly when drifting and i want more angle to look better and reduce the chance of spinning out.
Old Jun 20, 2009 | 01:19 AM
Targatheory's Avatar
i thought the agency power/evo-r rear endlinks were height adjustable?
Old Jun 20, 2009 | 01:41 AM
Juice's Avatar
I made some poos
it has nothing to do with endlinks, and nothing to do with the rear of the car.
Tie rod spacers are there to give you more steering angle so you can drift bigger angles.
Check out his other thread to see what I mean.
Old Jun 20, 2009 | 02:44 AM
The Great Dick
Here is the results. Took less than an hour to install and a good 20 minutes to trying to eye ball the tie rods.
Before
After
Old Jun 20, 2009 | 03:43 AM
Spinning Sushi's Avatar
I <3 Sushi
Who makes the tie rods and how much?
Old Jun 20, 2009 | 08:42 AM
Still don"t see how they don"t change the toe?
Old Jun 20, 2009 | 11:13 AM
The Great Dick
Poweredbymax makes them for only 10$. They also make knuckles and other great custom parts for really cheap. They are based in San Diego.
www.Poweredbymax.net
Old Jun 22, 2009 | 07:08 PM
you're not suppose to add these without the rest of the upright/control arm kit that puts the steering arm further outboard, by itself the spacer accomplishes nothing ...
Old Jun 23, 2009 | 09:40 AM
The Great Dick
They do add steering angle. I don't how your going to tell me that when the results are right in front of me.
Old Jun 23, 2009 | 10:38 AM
rotary.enthusiast's Avatar
The Local Idiot
The spacers that go between the steering rack and the inner tie rod can increase the steering angle. The way it works is that the spacer is small enough that it slides inside of the rack, allowing you to turn the wheel further before hitting the stop with the inner tie rod end.
Assuming there are enough threads on the tie rod, you can fix the jacked up toe this will cause, but you will have less threads making contact between the rack and inner tie rod, which is a bad thing. A more proper solution IMO would be new inner tie rods.
Old Jun 23, 2009 | 12:35 PM
Kennetht638's Avatar
You don't get something for nothing here, because moving the tie rod inner outward also affects bump steer.
Old Jun 23, 2009 | 01:08 PM
The Local Idiot
Yup. The tires will toe-in over bumps because of this mod. Unless you're a hard-core drifter, there isn't a lot of point to this. I've never had a hard time making a U-turn or getting into a parking spot in my 8
Old Jun 23, 2009 | 01:47 PM
The Great Dick
Which is why it is recommended to use blue thread lock when installing.
Also I hit the track and drift at least once a month which is a lot. A very worthwhile mod in my honest opinion.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
yankeepicker
Sep 11, 2015 05:42 PM
