On my way to succes!
Old Jun 9, 2009 | 07:50 AM
always.anthony's Avatar
is looking for his torque
in car audio that is.
UPDATE: SUBWOOFER and WIRING KIT just came in, AMP is on its way and for a LOC wondering if i got an adjustable one, what would settings be?
what is security token missing mean? i need to upload pics to see if its safe to run the power wire through this grommet, it goes through the fire wall okay, but it touches a pipe, and i think it might be either an ac or heater pipe
Old Jun 9, 2009 | 09:16 AM
firebirdude's Avatar
User and Abuser
Good luck with that 10" .....
Old Jun 9, 2009 | 06:18 PM
why "...."?
and does anyone know if a subwoofer box can be made out of plastic?
Old Jun 9, 2009 | 08:32 PM
Evan0925's Avatar
I Can Has Rx8?
Originally Posted by always.anthony
why "...."?
I've seen "boxes" made out of Lexan tube. The cylindrical design is sturdy enough. However, I wouldn't suggest making a box out of plastic. Why did you want plastic?
Fiberglass/CarbonFibre will give you a great result.
Old Jun 9, 2009 | 10:23 PM
i'm gonna reverse mount the subwoofer in between the back seats. so the driver will be visible in the cabin, and all i would have to do is seal off the box that is already made out of plastic.
and the boston g5 is rated at 450 rms at 4ohms would http://www.kenwoodusa.com/Car_Entert...iers/KAC-9104D
would running at 500 rms give me any problems? or should i look for less power?
is this a good deal? http://cgi.ebay.com/KENWOOD-KAC-8104...3%3A1|294%3A50
Old Jun 9, 2009 | 11:37 PM
Socket7's Avatar
ಠ_ಠ
1. I don't think a 10" would fit in the passthrough.
2. I'm sure the center pass through "box" is not going to have enough air volume to make the sub work properly.
Old Jun 9, 2009 | 11:42 PM
cjkim's Avatar
^noob
I believe a single 10" has been done in the passthrough. Can't remember the username though. But I believe his box extended out into the trunk.
Agree with #2
Old Jun 9, 2009 | 11:45 PM
05rex8's Avatar
sold the 8... :(
^Renesis07
edit: here's a post: https://www.rx8club.com/showpost.php...2&postcount=15
Old Jun 10, 2009 | 12:03 AM
i'm reverse mounting, the driver will be visible and the sub will be facing towards the rear.
like http://www.biline.ca/Pictures/basement/isobaric_sub.JPG
the g5 works best in a .5 ft ^3 sealed enclosure, if i seal the box already existing i have plenty.
Old Jun 10, 2009 | 10:15 AM
Socket7's Avatar
ಠ_ಠ
Best of luck to you then.
Old Jun 10, 2009 | 04:56 PM
thanks thanks
and once again, would it be bad to run 500 rms to a 450 rms sub?
pics coming soon!
Old Jun 10, 2009 | 05:03 PM
Socket7's Avatar
ಠ_ಠ
Nah, it'll probably be fine. Chances are you wont be able to turn it up loud enough to fry anything. Unless you're already 3/4ths deaf.
Old Jun 10, 2009 | 07:02 PM
anyone know what i should do for connection to the amp, i've read on forums loc is best, but after hu, or after bose amp? i've read good opinions on both. and i get people saying speaker level inputs suck, and that they're great. what should i do concerning amp hook up to car'?
Old Jun 11, 2009 | 11:59 AM
WikkedOne's Avatar
Deals on wheels
This was best answered by Socket7 in a post earlier today...
the signal from the head unit itself is not a true speaker level signal. After the bose amp is. You may be able to make it work before the amp, but your gains will need to be much higher and you wont get as much bump, or sound quality.
For a complete system upgrade, sure, tap before the bose amp, that's the way I did it. For a bass upgrade though, tap after the amp. Otherwise you'll be feeding a much different signal to your sub then your other speakers, making it sound unbalanced. The Bose amp applies an EQ curve to the signal and you want that curve to be played by your sub so it will match the rest of the bose system.
In the case of a full system upgrade, you want to be able to apply your own EQ curve, and so tapping before the bose amp is preferable.
Old Jun 11, 2009 | 03:36 PM
oh wow....i completely missed that.
Old Jun 16, 2009 | 05:02 PM
rotary crazy
48
Nov 15, 2005 12:38 PM
Patrick
Europe Forum
Aug 29, 2003 09:26 AM
FoMoCo
13
Mar 12, 2003 06:55 PM
