Transmisssion Oil
Old Jun 5, 2009 | 08:52 AM
RX8 NY's Avatar
Transmisssion Oil
Does anyone know how to check the level of the manual transmission fluid?
Old Jun 5, 2009 | 09:07 AM
jmc23200's Avatar
I'm guessing you havent searched the forum or read your owners manual. If you do not have a manual, go to dubdubdub dot mymazda dot com and download one.
Old Jun 5, 2009 | 05:35 PM
rx8cited's Avatar
Senior Member
jmc23200,
Good tip to download the owner's manual.
What does your manual say about check the manual transmission fluid level? If it's like mine, it says NOTHING about check MT fluid live ...... unless I'm blind.
Anyway, OP posted and got answered at this thread: https://www.rx8club.com/series-i-tech-garage-22/transmittion-oil-175626/
Old Jun 5, 2009 | 05:58 PM
cuz you NEVER have to check MT fluid levels. not even when you're replacing the fluids.
the fill hole is there for a reason ... *sigh* ... people ... *sigh*
Old Jun 5, 2009 | 06:05 PM
rx8cited's Avatar
Senior Member
Dude, don't you get it ...... if you're new to MTs how the f**k would you know this? You see to have forgotten when you were new to cars.
Old Jun 5, 2009 | 07:02 PM
Im sorry but I DO know that you dont have to check MT fluid even BEFORE I got my first MT car
he also failed for not searching.
he also ALSO failed for not reading his manual. don't have it? He got a Mazda, he got a computer with internet access, he "found" this web site. but is mazdausa.com 's owners section that hard to find ?? failed.
One more thing, what is "transmisssion" anyway ? failed.
oh yes. i would like to see you to reply to every single n00b post like the above ... for ... another 5000 times ... then we talk
Old Jun 5, 2009 | 08:28 PM
ken-x8's Avatar
Im sorry but I DO know that you dont have to check MT fluid even BEFORE I got my first MT car ...
You kids today! Back when I was your age, checking gearbox and rear end oil was part of a lube job. Somewhere between changing the engine oil and hitting every zerk fitting with grease, you'd remove the fill plugs for a look.
Ken
Old Jun 6, 2009 | 07:42 AM
Ken
Hey hey hey !
we're talking about 2009 right now !
who cares if the 80s 70s 60s 50s .... :P
I know 100 yrs ago there were no starter thing ppl gotta start their cars with their hands ...
Old Jun 8, 2009 | 08:07 AM
jmc23200's Avatar
jmc23200,
Anyway, OP posted and got answered at this thread: https://www.rx8club.com/showthread.php?t=175626
Thats because you dont have to. You should look for the flux compasitor section in your manual too. Since its not in your manual, does it mean you have one? Good luck finding out about your left and right falangy.
Old Jun 8, 2009 | 09:28 AM
Huey52's Avatar
Registered Zoom Zoomer
Just stick your finger in the upper, fill, transmission hole. The fluid should be flush with the lower edge of the fill hole. When filling the transmission (topping off or after a drain), when the new fluid starts to run out the the fill hole the level is proper. Use Redline MT-90 btw.
Old Jun 8, 2009 | 02:42 PM
jmc23200's Avatar
LOL. Way to start a new thread for the guy. Now you get to answer his following questions
Old Jun 8, 2009 | 02:50 PM
Winning 8's Avatar
Hot Pit
have to jack up the car and make sure the car is level.
Old Jun 8, 2009 | 03:19 PM
Huey52's Avatar
nah, that's it; one to a noobie customer. I expect he'll search "transmission DIY" from here on. "Teach a man to fish."
Old Jun 9, 2009 | 07:48 AM
jmc23200's Avatar
Teach a man to fish and he will turn you into a slave and rape your women and children. You gotta keep them dependent enough that they still need you
Old Jun 9, 2009 | 09:01 AM
RX8 NY's Avatar
Thanks for the responses, for the most part. This was pretty much what I found searching, and I just wanted to make sure I wasn't missing anything... Thanks again for the help, and hopefully I can figure out why the shifting isnt as smooth as it used to be.
Old Jun 9, 2009 | 11:23 AM
Isnt as smooth simply means your "transmisssion" is(are) having problem(s).
Old Jun 9, 2009 | 11:28 AM
Huey52's Avatar
Drain and replace with Redline MT-90. Good stuff and you'll eliminate the fluid vitality variable as you further troubleshoot.
Old Jun 9, 2009 | 01:10 PM
delhi's Avatar
Grand Chancellor
Anyone tried Castrol Syntec 75w90?
Old Jun 9, 2009 | 01:15 PM
Huey52's Avatar
75w90 is for the differential, not the transmission.
edit: noting your 2300+ posts I assume you know the difference and were just taking the thread in a somewhat-related direction.
No, have not tried Castrol Syntec 75w90 in the differential, but I'm a fan of Castrol 5w-30 in the oil pan.
Old Jun 9, 2009 | 04:47 PM
O'Renesis's Avatar
I have heard of this as a good RX8 manual transmission oil- http://www.opieoils.co.uk/p-744-cast...-gear-oil.aspx
but not tried it yet.
Old Jun 10, 2009 | 07:48 AM
jmc23200's Avatar
I would shy away from anything "universal" since they do not test these on every different type of car.
"It meets the need for a 'universal' gear oil which can be used in automotive manual gearboxes, transaxles, transfer boxes and final drives"
Since it will work for all of these, I am assuming that there are additives that will allow it to work in all of the different applications. Do you really want extra additives that may or may not damage any of the 8's internals? Stick with something that others have already tested.
Old Jun 14, 2009 | 10:57 PM
fahrfegneugen's Avatar
It could be leaking.... also our Subaru Impreza manual trans has a dipstick. Though that is a bit different cause it has a differential in it too.
too busy to read the rest... so here is a reply :D
If it wasn't said, raise the car level and open the fill plug. Fluid will probably come out a little or it will be up to the bottom of the plug. In an RX8 the gear changes can get notchy on stock fluid and of course when the fluid is old, so a lot of people change to Redline MT-90. If you haven't done so, it might be a good idea.
Old Jun 16, 2009 | 06:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
wow....this thread is about to equal FAIL....not quite there but almost.....
Old Jun 16, 2009 | 06:39 PM
mscamp02's Avatar
Blue Bullet?
+1
just waiting to see where it goes.....but just so you know you dont even need to worry about it unless for some odd reason you are leaking (get fixed immediately!) or just changed out your clutch (this could cause you to spill some of it although you should just go ahead and replace it if your already that deep into your car)
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
