Finished The Turbo Install Today. Couple Questons
Old Jun 3, 2009 | 04:55 PM
MFslacker22's Avatar
Finally finished it today and took it for a spin... WOW what a difference. Anyway...Here is a pic of the engine. I have a plug, as you can see on the bottom right corner, that comes off the MAF wire harness that connected to some thing on the airbox. The question is what do i do with this plug?
also, does anyone know of a gauge mount that go on that little vent above the driver main ac/heat vent?
thanks
Old Jun 3, 2009 | 05:48 PM
pdxhak's Avatar
Official Post Whore
Zip tie to the MAF harness.
Old Jun 3, 2009 | 05:49 PM
yes, there is a pod that fits there.
one sec...
Old Jun 3, 2009 | 05:50 PM
Kane's Avatar
Senior Member
As for the AC vent gauge pod - there was a guy making them but I don't know if he sold them all....
Advanced Search is your best friend.
keywords: Vent Pod
search Titles Only
you get this: https://www.rx8club.com/showthread.p...light=vent+pod
Old Jun 4, 2009 | 02:37 AM
Brettus's Avatar
Boosted Kiwi
Are you running a boost controller or just at stock boost ?
Also : you would be better with a catch can on your crankcase vent .Unless you actually want your turbo to be caked with oily goo of course ....
Old Jun 4, 2009 | 05:16 PM
its stock for now. I am running the emanage ultimate and it is boosting smoothly, it just stalls sometimes while coasting. Will fix #2 solve the stalling? Its idling fine and runs pretty good so far. Its wet out today so I will let you all know how it is later on. Why do you ask if i have a boost controller?
Old Jun 4, 2009 | 05:50 PM
MazdaEight's Avatar
Congrats...that is a cool looking BOV, what kind is it?
Old Jun 4, 2009 | 06:05 PM
Greddy type-rz. I think its a limited edition. It sounds sick.
Old Jun 4, 2009 | 08:14 PM
Brettus's Avatar
Boosted Kiwi
With that BOV (IE closed at idle & vented to atmosphere)you need to be careful how you set up your boost controller .
BTW I would suggest you don't get a boost controller until you get better engine management .
Old Jun 4, 2009 | 11:03 PM
Will it be ok if I leave it stock? Honestly, because I dont really want to spend another $700. Also, do you know why it stalls sometimes when coming to a stop?
thanks
Old Jun 4, 2009 | 11:07 PM
TopGear8's Avatar
mkuhnracing.com
^Bad idea to get a turbo if you wern't prepared to spend extra money...
Old Jun 4, 2009 | 11:38 PM
chickenwafer's Avatar
Nope
^LOL, true story
Also, make sure you have a check valve in your Jet Air hose, it doesn't look like you do.
And yes, put in an oil catch can do your turbo doesn't ingest oil
And you really need to re-plumb your w/g signal (fix #2)
Old Jun 4, 2009 | 11:48 PM
Brettus's Avatar
Boosted Kiwi
thanks
I think you will be fine with the ultimate so long as you aren't tempted to up the boost .
Where did you plumb the jet air line to ? If jet air is the line next to the one from the oil filler neck then that could be your problem - no check valve .However i think that is the omp line and you have jet air just before the throttle body . Is that how you have it ?
If not jet air it could be a vac leak somewhere else .
Old Jun 5, 2009 | 05:17 PM
Here is a more detailed picture, sorry the quality is so poor I took it with my phone.
The check valve is on that the line all the way to the right, it goes to that sensor that connects to the emanage. The line going to the left goes to the waste gate. Let me know what i did wrong
Old Jun 5, 2009 | 05:27 PM
heres another one. The blue line in the picture has the check valve and the orphis(sp?) fitting in it. As I was taking the picture I noticed the one with the check valve blew off! I guess thats why it wasn't idling. I am going to clamp all these vacuum hoses down now. If I loosen the BOV, will the lines not blow off as easy?
thanks
Old Jun 5, 2009 | 05:48 PM
Brettus's Avatar
Boosted Kiwi
You need to do Greddy fix#2 to stop blowing all your lines off . You will be seeing 20psi+ at part throttle (before the throttle plate) unless you hook your wastegate actuator to the turbo outlet .
Hope that is not a check valve going to emanage - should be a filter if anything....
Do you know where your jet air line is going ?
Old Jun 5, 2009 | 06:01 PM
ok, then i need a boost controller right? Why do you say to be careful with it in your previous posts? Can i just get a T-fitting and connect the line going to the wastegate to a pipe connected to a boost line? Which jet air line are you talking about?
thanks
Old Jun 5, 2009 | 06:13 PM
Brettus's Avatar
Boosted Kiwi
thanks
Why do you need one ? Don't see how you got that idea . Boost controllers are the devil if you are not 100% familiar with your setup your tune and how everything works - just my opinion
If you must have one - and only want to raise the boost a few psi one of those manual ones may actually be a safer option .
Have a read of this thread https://www.rx8club.com/series-i-major-horsepower-upgrades-93/getting-most-out-your-greddy-turbo-without-breaking-bank-172542/
[/QUOTE]
anywhere between the turbo and the intercooler is ok . Closer to the turbo is better.
The jet air is one of the three lines that was going to the accordian on the stock setup .
I can only see two of those in your pics -can't see where the other goes .
Old Jun 5, 2009 | 06:16 PM
Oh i didnt know this. I thought you needed one because in the definative fixes posted by mazdamaniac he said "the drawback is that the net maximum boost in the intake manifold will be about 2 PSI lower on cars not equipped with boost controllers" for the number 2 fix.
Old Jun 5, 2009 | 06:22 PM
Brettus's Avatar
Boosted Kiwi
/\ yep - that is true .
Old Jun 5, 2009 | 06:35 PM
so will I need a boost controller or not?
Old Jun 5, 2009 | 07:44 PM
Brettus's Avatar
Boosted Kiwi
if I was you I would do fix # 2 then just adjust up the rod on the wastegate actuator to as short as possible . That should give you 6-7psi without a boost controller which is where you should leave it until you become more familiar with tuning etc .
So NO - don't get a boost controller
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Solmors
Aug 21, 2015 10:11 PM
Shinka84
20
Jul 25, 2015 12:58 PM
