OBD Baseline
Old Jun 2, 2009 | 07:53 PM
merkidemis's Avatar
OBD Baseline
I am looking at buying a used RX8, and I am bringing my OBD-II scanner with. However, it would be good to have a baseline to go against. Anybody have their readings off a well running, unmodded car?
Old Jun 2, 2009 | 09:04 PM
auzoom's Avatar
Hmmmmmm.........
What is it you expect to get from the OBD ?
Old Jun 2, 2009 | 10:22 PM
merkidemis's Avatar
Oh, things like idle speed before and after the test drive, if its running rich or lean, ability to hold a voltage, intake temps, O2 levels, etc. Obviously testing for a stable idle is easy, but some of the others would be meaningless numbers without something to compare against.
Old Jun 3, 2009 | 03:37 AM
auzoom's Avatar
Hmmmmmm.........
Its irrelevant. At idle AFRs should run as close as possible to stoich'. Intake temps should be a few degrees above ambient after a good long cruise.
My take on it anyway.
Old Jun 4, 2009 | 10:42 AM
merkidemis's Avatar
So, if you are of the opinion that monitoring an engine under test will not yield anything useful, I'm curious to hear what you think the meaningful use of a scanner is.
Old Jun 4, 2009 | 02:40 PM
auzoom's Avatar
Hmmmmmm.........
Irrelevant was in relation to the "baseline" part. If you really want to know the "baseline of your car, then pull the calibration and see what its supposed to be doing.
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
MANIACman
Nov 11, 2015 10:58 PM
Fickert
Sep 9, 2015 01:21 PM
