Water temp gauge problem
Old Jun 1, 2009 | 06:15 AM
leechieboi's Avatar
Now FI perpetual learner
Just got done hooking up my nordskog water temp gauge.. and doesn't seem to work. temp stays at 375 deg F.
Here's my setup.
did i hook up anything incorrectly?
Old Jun 1, 2009 | 07:26 AM
elf's Avatar
elf
What pointy ears?
Here's my setup.
Yup. You hooked up both the ground and the gauge's sender unit wire to the same terminal. The correct ground location is the sending unit's body:
http://i126.photobucket.com/albums/p...f/IMG_0213.jpg
http://i126.photobucket.com/albums/p...f/IMG_0215.jpg
Also, see Jedi54's DIY (sticky in this forum).
Old Jun 1, 2009 | 12:38 PM
leechieboi's Avatar
that's what i was thinking. thanks.
Old Jun 1, 2009 | 12:42 PM
Elf to the rescue!!! Nicely done good man.
leechieboi: you're in good hands with Elf helping you out but if you need anything just let us know.
P.S. as elf mentioned, check out my sticky thread.
Old Jun 1, 2009 | 08:56 PM
leechieboi's Avatar
yea thanks. jus solved it. i work at a machine shop so i jus fabbed up a ring to go around the sensor body with a threaded hole i put a screw into to keep it in place/connect the grounding wire
Jesus Martinez
44
May 6, 2025 08:09 AM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Octomus
Sep 3, 2015 11:40 AM
talonhart2
Aug 26, 2015 04:14 PM
