Replacing 05 PCM
Old May 31, 2009 | 09:29 AM
cajunrx8's Avatar
Rotary Crawfish
LA Replacing 05 PCM
After an exhaustive search that solved nothing, I want to know if I can replace my PCM with a later build date unit.
I have a early 05 car built in sept 04 and don't have the delayed trunk release timing.
After a VIN break it was incorporated, can I change my unit to get this function?
Old May 31, 2009 | 05:15 PM
I would think that feature is a software flash type upgrade, and likely effects the keyless security module. You would likely have to upgrade both if it won't work on the 04 ECU
I seem to remember that using the 05 switchblade key came with the delay...so it might be as easy as having a new transmitter??
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
TeslaMSI
Dec 10, 2015 01:10 AM
TJSiegrist
Sep 10, 2015 09:29 AM
whitelight42
Series I Engine Tuning Forum
Sep 2, 2015 05:02 PM
