Turbo installation problems
Old May 29, 2009 | 05:57 PM
MFslacker22's Avatar
I started putting the Greddy kit on today... ran into a few problems
1. The oil line doesn't seem to be long enough. Is the T-fitting suppose to face up or down?
2. The studs that connect the turbo to the manifold and the turbo to the down pipe piece dont seem to be long enough for the washer/nut to fit on securely.
3. How important is the aluminum head shield thing because I have a feeling it will fall off as soon as it gets wet.
4. Is the down pipe piece suppose to go on last or is it suppose to go up all in one piece because in the instructions it didn't say to put the down pipe piece on with the turbo and I cant seem to fit it in with the turbo and the engine mount bolted up.
thanks
Old May 29, 2009 | 07:10 PM
PhantomRX-8's Avatar
Bad Ass
Im in the process of doing my install too and you are alittle ahead of me so I can only help with number 2, you have the studs in upside down. The longer threded side should point up. The short threaded side goes into the manifold.
Old May 29, 2009 | 08:39 PM
gregs's Avatar
Pull My Finger
Did u buy a used kit or is it new?
Old May 29, 2009 | 09:12 PM
trancesimulator's Avatar
1. get rid of that T and buy a oil filter sandwich plate (where u located i have one for sale)
2. are teh studs in the right way? the studs on turbo and manifold there is a short threaded side and long threaded side make sure the short side gos into the manifold and into the turbo houseing.
3. that heat sheild that is supplied with the kit or it comes with that u stick onto the car is crap buy some beatter heat shielding
4. install turbo then install downpipe and then u can install the midpipe
Old May 30, 2009 | 07:16 PM
Where did everyone install their e-manage thing. I was going to put it in the engine bay but figured it would get too hot. Also, how important is the heat shielding? Because I put what they supplied around the turbo and am worried that may not be enough.
thanks
Old May 30, 2009 | 07:24 PM
Bad Ass
I think most people put the eManage in the glove box. If you have the money, go with a Cobb. Emanage is crap now that we have better alternatives. Not sure about the heat shielding. I upgraded the turbo to be water cooled so Im only going to put the with some heat tape on the firewall, not wrapping turbo.
Old May 30, 2009 | 07:53 PM
Is the e-manage good if I just bolt the kit on and leave it? I dont plan on doing anything else and dont want to spend any more money.
Old May 30, 2009 | 09:04 PM
staticlag's Avatar
The Professor
E-manage Blue = crap
E-Manage Ultimate = good
If you don't change the boost level at all it might be ok, but if you plan to turning up the boost past 6 psi you are going to need a custom tune and a few other upgrades.
Old May 30, 2009 | 10:35 PM
Do yourself a favor and get rid of the E-manage.......
There are better options out there...
Old May 30, 2009 | 10:47 PM
agreed..its not worth the headachs and problems go with cobb and u will end up feeling better with the safety
Old May 31, 2009 | 09:40 AM
What kind of headaches and problems will I have if I use it?
Old May 31, 2009 | 11:22 AM
first of all u wont get alot of good features if u use the emanage....Alot of people blow there motor with emanage go search the forum on problems and how many people hate it... accessport is worth the money thats why im saving for it...I personally never used emanage nor accessport but from wut everyone post and wut i read its garbage and im willing to beleive wut people talk about on here exspecially MazdaManiac
Old May 31, 2009 | 11:28 AM
Rotr8's Avatar
whines all the way home
If you are asking these questions chances are you should not have chosen to go FI...
Old May 31, 2009 | 01:56 PM
Thanks for the helpful post!
Old May 31, 2009 | 05:06 PM
chickenwafer's Avatar
Nope
A blown engine is the biggest
The Ultimate works ok but not the best. The Cobb AccessPORT doesn't cost much (in terms of engine management) so it works fantastic.
xAgyex
Jun 3, 2026 03:47 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
rotorocks
47
May 11, 2016 03:23 PM
RicerX1
Jan 11, 2016 05:59 PM
Belalnabi
Jul 17, 2015 07:48 PM
