View Full Version : anyone have a sway bar?
AndreS123
05-26-2009, 07:18 PM
I'm looking for a front sway bar for an RX8... anyone have one local to the Seattle area that they have taken off?
Spinning Sushi
05-26-2009, 07:20 PM
Please be more descriptive.
Are you looking for the base model or sport model sways?
Are you looking for the front or rears?
Do you need the bushings and endlinks that go with it? You will need those too if you're putting it in a Miata.
Please be more specific.
AndreS123
05-26-2009, 07:35 PM
I prefer having the bushings with it, but I don't need the end links, I need to measure it to be sure it fits first....
which model? prefer 24mm or larger diameter... its going on a street/strip car that will have it disconnected at the strip.
If it fits, it'll be going on a LS1 swapped '88 RX7... the stock bar bend hit the oil pan so I took it off.
RawrX8
05-27-2009, 03:01 PM
Sounds like you should run a dry sump.
AndreS123
06-04-2009, 02:32 PM
not doing a dry sump for the time being, just looking to get some measurements on an RX8 sway bar..... and possibly purchase one.
RawrX8
06-04-2009, 02:56 PM
In about another week my rear PT sway shows up and ill be swapping them out. If you havent found one by than and can wait ill have one.
