storing oil in trunk
Old May 25, 2009 | 08:39 PM
mlfarrell's Avatar
If you do, what do you guys use to keep your oil jugs + funnel stuff in your trunk? I was using wal-mart bags, but the oil is just going right through them and getting on my tarp and other stuff in my trunk.
any suggestions?
Old May 25, 2009 | 08:49 PM
HWK11's Avatar
Lighting Yellow
the middle by pass thing. it can hold 3 oil bottles perfectly. or you can put 1 bottle and funnel in there. and if you get oil in there its easier to clean.
Old May 25, 2009 | 08:50 PM
HockeyRX-8's Avatar
TNC
strap down the oil with the buckle from the tire inflater kit.
Old May 25, 2009 | 08:52 PM
amstarvid's Avatar
ZM ZM X 8
I keep a small funnel, and some paper towels in a small zip lock bag, and then have one quart of oil strapped in with the tire repair kit. Done this for 3 1/2 years and almost 70K miles - not a drop of oil anywhere...
Old May 25, 2009 | 08:57 PM
tbk's Avatar
tbk
ლ(ಠ益ಠლ)
i just throw it in there with cleaning supplies and crap, no spills yet.
Old May 25, 2009 | 09:04 PM
G-ReX's Avatar
A Torque-Free Zone
I cut a Castrol bottle in half and use the top as a funnel, then nest it in the bottom half to catch drips. I keep it in between the space between the windshield washer tank and the fender.
Old May 25, 2009 | 09:07 PM
HWK11's Avatar
Lighting Yellow
i tried keeping it in there but its so hard to take out....
Old May 25, 2009 | 09:15 PM
PSTNLSS's Avatar
The Former PSNTLSS
I store my oil bottles near the exhaust tips attempting to catch and recycle the unburnt oil . Just use the tire inflation kit thing. Or get one of those bags to keep car cleaning supplies in. Get them at like Target or Walmart. Small Trunk organizer. I keep my oil, funnel and cleaning supplies in it.
Old May 25, 2009 | 09:51 PM
myriadshalaks's Avatar
rot8ing
i just wait till i get home.
Old May 25, 2009 | 10:01 PM
Burton's Avatar
Rotary Rambler
I just use the little castrol bottles (the size escapes me) in a bag, If you are careful you dont need to use a funnel so there is no cleaning of that to be done
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
I just put an emergency quart of 5W-30 in the cubby in the trunk.
Old May 25, 2009 | 10:02 PM
JinDesu's Avatar
went back to srsly broke
The oil bottle stays in the bottom tray, wedged in between a bunch of stuff. The funnel is kept inside the original plastic bag it came with (I make sure to wipe off the oil before returning it).
Old May 26, 2009 | 12:32 PM
runriderive's Avatar
MN
I do what Burton said: Castrol bottle, cap on tight, throw it in the trunk, no funnel. Haven't made a mess yet. To each their own.
Old May 26, 2009 | 12:53 PM
Drumm09's Avatar
I actually keep the oil, fennel and small paper towel roll inside a liquor box in the trunk. It's perfect because the box is short but tall and flat.
Next time you drive pass a liquor store, go inside and ask if they have any empty liquor boxes (they always do) that you can have. Then take your oil, fennel (which I keep inside a regular plastic bag) and put inside and in your trunk.
Hope that helps.
Old May 26, 2009 | 12:59 PM
Vlaze's Avatar
The Angry Wheelchair
How about just tighten the cap on the bottle down? Problem solved. I could toss it behind my seat for any vehicle I've ever driven and it never leaks. Why should it leak? Unless you deformed or stripped a thread on the cap or the bottle, don't tighten it down or it gets punctured, not sure why you'd be having an issue.
Old May 26, 2009 | 01:02 PM
TheWulf's Avatar
My 8 looks like a Smurf
I just got the OMP adapter and now I don't have to worry about oil at all
Old May 26, 2009 | 03:12 PM
Teedat's Avatar
That's where I keep my premix. Great place
ditto
Old May 26, 2009 | 03:39 PM
DarkBrew's Avatar
Extraordinary Engineering
ON
I do this as well; Three bottles plus paper towel. I refill my 1 litre bottles from a four litre jug. As long as you fill them 3/4 of the way and no higher you'll be able to hit the oil filler every time and avoid spillage. No funnel required.
Old May 26, 2009 | 04:14 PM
invasion08's Avatar
I store my oil, premix and the bottle i use to measure and add my premix in my cargo net. Took a couple of black zip ties and made holders for all 3 containers, so they will not tip over or spill.
Old May 26, 2009 | 04:21 PM
delhi's Avatar
Grand Chancellor
I just put the Castrol GTX in a plastic bag and keep it in the trunk cubby hold. Works great. No spill. And even it leaks, the plastic bag will catch it.
Old May 26, 2009 | 04:29 PM
Socket7's Avatar
ಠ_ಠ
I keep a bottle of 5w-30 under the hood to the left of the washer fluid bottle.
Not sure why you'd need a funnel. Bottles of oil are designed to pour smoothly.
Old May 26, 2009 | 05:48 PM
Use a couple freezer gallon Ziplock storage bags and it should be fine. Once you pop the bottle open, just put a new one back in. I wouldn't put a partially open bottle back in my trunk unless I was on the road since the seal may not be 100%.
Old May 26, 2009 | 06:13 PM
New Yorker's Avatar
I live in the city and don't have a garage, so I keep a bottle—full or open—in the cargo net attached to rear of the trunk (the side right next to you when the trunk is open). Have never had a spill.
That said, if I had a garage I wouldn't store oil in the car. I mean, it's not like one day the oil level is gonna drop so suddenly that you can't wait to get home or pull into a gas station. I guess I might carry some if I were traveling though rural areas where it might be hard to find 5W-20.
Old May 26, 2009 | 06:14 PM
cfm251's Avatar
I buckle it down in a child seat, safety first!
honestly i just keep a castrol bottle under the seat, no spills and more convenient.
Old May 26, 2009 | 06:43 PM
phobi's Avatar
dammit i love my car...
I managed to get the trunk storage bin used from another forum member, bottles of oil stay in either campartment under the lid and my trunk has a flush floor I like the tip of filling the bottles to 3/4, will do next time.
