Gas cap and CEL question
Old May 24, 2009 | 02:49 PM
jackalpupz's Avatar
Okay, So my CEL light just came on for no reason the other day. Car is running perfectly fine. I couldnt figure it out but when I went to gas up, I noticed my gas cap was not even screwed on. Then I tried to put it back on but its stripped. So I will have to go buy a new gas cap. Question is, once I get a new gas cap, will the CEL go away on its own? Or does a tech have to turn it off?
Old May 24, 2009 | 02:52 PM
invasion08's Avatar
it will go off on its own after a few drive cycles
Old May 24, 2009 | 03:01 PM
jackalpupz's Avatar
Oh okay, thanks for the quick answer!
Old May 24, 2009 | 10:28 PM
Lebren's Avatar
RX8club group buy vendor
is it still under warranty, they may give you a new cap.
Old May 24, 2009 | 10:48 PM
buy a new one, cost probably 10-15 bux
Old May 24, 2009 | 11:00 PM
Maries8's Avatar
I had to pull the Room(?) fuse, wait at least 60 seconds, then put it back in.
Old May 25, 2009 | 03:41 AM
jackalpupz's Avatar
Oh I just bought one at Kragen for 6 bucks. It works fine. I will see if the CEL turns off in a couple days.
Old May 25, 2009 | 10:49 AM
Maries8's Avatar
You might consider resetting it ASAP, just to make sure you're not running the car while something different is wrong.
Old May 25, 2009 | 10:59 AM
mulkio's Avatar
Under-prepared
Search ! Cel po442
Old Jun 13, 2009 | 09:05 PM
miater's Avatar
I had my cap replaced under warranty. It is running better than it was - it had a slight knock, I replaced the plugs, knock still there. After they replaced the cap , no more knock. I put a new battery in it while I was at it.
Old Jun 13, 2009 | 11:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
just remove the battery cable for a few minutes that will reset it.....or go to autozone and have them erase it....CEL usually bugs me so i try to get it off there asap....
Old Jun 14, 2009 | 10:12 PM
ken-x8's Avatar
I vote for going to Autozone and having them read the code. Always good to know what it was, even though gas cap off is really good evidence it was one of the gas cap codes.
I'm curious - how did your cap manage to get stripped? The cap may be plastic, but those threads are pretty big.
Ken
Last edited by ken-x8; Jun 15, 2009 at 12:31 PM. Reason: added "good" per 05RX8man's keen eye...thanks
Old Jun 15, 2009 | 09:32 AM
04RX8man's Avatar
^good ?
Old Jun 15, 2009 | 10:12 AM
bruce_van's Avatar
Bruce Van
Mazda has some sh!ty gas caps. I've had to replace mine a few times under factory warranty. My friend has a CX-7 and she had the same problem.
Old Jun 15, 2009 | 03:34 PM
jackalpupz's Avatar
It ended up being just the gas cap. Bought a new one and the CEL turned off the following day.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wankelbolt
Sep 9, 2015 03:43 PM
Solmors
Aug 21, 2015 10:11 PM
GracefulShanks
Aug 18, 2015 11:40 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
