need some help- front sway bar measurements
Old May 24, 2009 | 01:56 AM
AndreS123's Avatar
I'm looking for a sway bar for a different application, I'm considering using an RX8 front sway bar.
so.... I need some dimensions of a stock RX8 front bar, if someone would be gracious enough to help me out.
here's some dimensions that would be really helpful:
diameter
distance between mount points (inside to inside of bushings & outside to outside)
width @ end link mount points (inside & outside dimensions)
radius of rotation
much thanks in advance!
Old Jun 4, 2009 | 04:53 PM
AndreS123's Avatar
Anyone?
Old Jun 8, 2009 | 04:52 AM
distance from main bar centerline to the endlink hole centerline is 7.375" (side dimension)
the distance between the outside bar ends where the endlinks mount is 42" (very bottom dimension)
the arm thickness where the endlinks mount is 1/4" (41.5" distance between the inside endlink mounting points per your arrows)
I'll have to measure the pivot bushing mounting point dimensions
Old Jun 12, 2009 | 12:38 AM
The top two center section measurements are 30" and 33" respectively
Old Jun 15, 2009 | 03:28 AM
AndreS123's Avatar
Thanks! looks like it will fit! I also want to confirm that they don't have any bend in the middle... it's straight across between the mounts, correct?
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
