After Dealer Transmission Rebuild - Clutch Much Softer
Old May 20, 2009 | 03:09 PM
SilverHokie's Avatar
I'm Delaware Fast
What I mean by this is my clutch pedal used to be pretty hard to push down. I purchased the car with 16k miles on it (05) and it has always been like that. Now that I have a new clutch/flywheel and new bearings, the clutch pedal is WAY easier to push down...almost as easy as my girlfriend's 09 Mazda 6.
The questions I have today are as follows: What would cause my clutch pedal to depress much easier? (I don't mind it)
Is this how it is supposed to be? The components were all replaced with Mazda OEM stuff under warranty.
I'm not a tramission guru by any means...I just find it interesting. I expected the clutch response and grip points to be different with the new clutch, but I did not expect the clutch pedal to depress easier.
Old May 20, 2009 | 03:10 PM
Spinning Sushi's Avatar
I <3 Sushi
I noticed that my clutch was insanely light when I bought the car brand new. The softness eventually became stiffer. I noticed that it started getting stiffer right after my throw-out bearing was starting to make noise.
Old May 20, 2009 | 11:49 PM
my guess is they got the right grease on the input shaft and the clutch disk is moving correctly..
dont ask me how i know.. btw, enjoy is is a bit weird is it not?
Old May 21, 2009 | 01:40 PM
tiresmoker's Avatar
Trust me, you're wrong
If the clutch is really "squishy" they may have not bled the slave cylinder properly/got all the air out of the line.
Old May 21, 2009 | 05:10 PM
YaXMaNGTO's Avatar
It's a Cavalier
Yah, they might have to bleed it... could be that or just a different feel from new fluid.
Old May 21, 2009 | 05:54 PM
renesisgenesis's Avatar
mod edit
just do some very aggressive starts and see how well it grips. I don't mean rev to 9500 and drop the pedal, but maybe 5000 with a pretty quick release. I would be more concerned with how well it actually grabs than the clutch feel.
Old May 21, 2009 | 09:08 PM
kersh4w's Avatar
Hit & Run Magnet
they put in a new clutch, thats why. worn out clutches are hard to push in.
its been like that on every single car that had a used clutch and went to a new clutch that i've ever driven.
and i think its hilarious you make the connection to your gfs brand new mazda 6. cause guess what? it has a new clutch.
if you dont like it, burn the clutch for a few minutes. :P
Old May 22, 2009 | 03:36 PM
RXheart's Avatar
Turbo
Clutch buring for the win!
Old Apr 1, 2010 | 08:38 AM
niko's Avatar
Don't worry
The master cylinder gets bled on new installs, leaving no pressure build up in the system. Drive it for a few days and it will be still again. It is a hydraulic system, so fluid flows through it. Give it some time.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Mane
Nov 20, 2015 12:16 PM
