For those with Electronic Background....
Old May 20, 2009 | 01:30 PM
ChrisRX8PR's Avatar
13B-RE
I need a simple electronic circuit that will help me accomplish what is depicted in the attached pic. This is for a more personal project but I know there is talent in this forum and I am no "wizzard" with electronics.
Basically when the switch is off I want the motor to turn in one direction indefinitely until and if it hits a stop at which point its Voltage would drop and its current would go sky high and then it shuts off (I'm guessing a current limiting or voltage drop cut off can be used)
When the switch is placed in the on position(12V) i want the motor to run in the opposite direction (reverse polarity) until and if it hits a stop at which point it shuts off again.
Any help is greatly appreciated.
Best regards,
Chris
File Type: doc
Old May 20, 2009 | 02:01 PM
Jon316G's Avatar
Grasshopper
You are better off using a 12V DC motor controller.
You'll need to find one within your voltage spec and has a current limiter installed.
This way you can adjust the limiter trip-point based on the motor and also adjust the motor speed.
Old May 20, 2009 | 02:15 PM
ChrisRX8PR's Avatar
13B-RE
The thing is that I don't need to control the motor speed. I just want it to run on 12v until it hits a stop and when it gets a signal to run the other way until it hits a stop. The signal is a simple 0 or 1 signal of 12V....
Chris
Old May 20, 2009 | 02:27 PM
Jon316G's Avatar
Grasshopper
But you need a way to monitor the current and also adjust it to your motor spec.
Having the flexibility to adjust to your motor is very important since different motors have different specs.
This is archived with a logic circuit on a controller board.
Or if the motor is moving something like a car window, you can wire limit switches on both sides so that voltage is cut-off when the switch is engaged.
Old May 20, 2009 | 02:39 PM
ChrisRX8PR's Avatar
13B-RE
That is exactly what I am looking for...something like that. Where can I get that?
I know how to make a circuit that will run one direction constantly(as soon as power is connected) when there is no input and the other direction when the +12v signal comes through...I just need something to shut it off when it reaches its "destination" and cant go any further to save the motor. Oh and I need it to be able to handle this on a regular basis...its normal operation will consist of it reaching the limit.
EDIT: I though you were talkign about Low Limit Voltage switches....I see you are talking about "physical" limit switches. Its moving something rotatory about 300 degrees so limit switches are out of the question.
Any other suggestions???
Old May 20, 2009 | 04:27 PM
staticlag's Avatar
The Professor
Maybe this might be helpful?
http://shop.voltelectronics.com.au/s...river-kit.html
Old May 20, 2009 | 08:48 PM
Jon316G's Avatar
Grasshopper
Originally Posted by staticlag
That's what I was getting at before, but he seems to want a physical limit switch instead.
I'll have to think of a simple way to wire this.
Old May 21, 2009 | 12:55 AM
ZOOMNRX8's Avatar
Could this be your ultimate goal? or maybe pick out what suits your application:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-auto-up-down-windows-86459/
Old May 21, 2009 | 08:20 AM
ChrisRX8PR's Avatar
13B-RE
Actually, I am trying to stay away from a physical limit switch. What I want is something that shuts off when a certain load, whether it be high amps or low voltage, is reached.
Thanks for the responses. Keep em' coming.
Chris
Old May 21, 2009 | 08:24 AM
ChrisRX8PR's Avatar
13B-RE
That would be ideal if instead of a potentiometer I could have an on off switch that would send it to one direction or the other...
Thanks....I am reading lots.....hopefully I'll sort this out...
Any more ideas?
Best regards,
Chris
Old May 21, 2009 | 02:14 PM
Jon316G's Avatar
Grasshopper
Thats why I recommended using a controller in the beginning.
Check this one out and see if it'll suit your needs:
http://www.electromen.com/commondata/vkem-140-12.pdf
Old May 21, 2009 | 02:30 PM
ChrisRX8PR's Avatar
13B-RE
Holy crap that just might work...I will read on and find out what kind of signal it can receive. Thanks man.
Chris
Old May 21, 2009 | 02:52 PM
ChrisRX8PR's Avatar
13B-RE
Do you know where exactly I can buy that? Can't seem to find it on the net or the usual electronics websites I know of.
Thanks.
Chris
Old May 21, 2009 | 03:00 PM
Jon316G's Avatar
Grasshopper
It appears that the company's distributors are international:
I'll try to find something similar that can be purchased within the US.
Old May 21, 2009 | 03:06 PM
rotarygod's Avatar
Are you trying to build an external circuit that can control the aux ports?
Old May 27, 2009 | 04:09 PM
ChrisRX8PR's Avatar
13B-RE
Anybody have any more input?
Thanks.
Chris
Old May 27, 2009 | 04:50 PM
Jon316G's Avatar
Grasshopper
I have a few other electrical engineers here at Rockwell who are helping me look for a good cheap controller (or alternative) for your application Chris.
Got a couple good ideas, now we are just looking for a commercially available way to purchase what we are thinking.
Not knowing fully what you're controlling is making this a little tricky, though I have an idea
Old May 27, 2009 | 10:29 PM
needadvice's Avatar
I'll draw you up a circuit. If you can solder simple stuff(like LEDs) you'll be able to make it yourself for a few bucks with stuff you can get at Radio Shack or the like.
Is it possible for you to stick a multimeter on the motor and see how much current it draws so i can pick appropriate components?
Old May 28, 2009 | 09:16 AM
ChrisRX8PR's Avatar
13B-RE
That would be great! I can build circuits.....I built a few ignition drivers for the RX-8 when we were experimenting before we started using internally driven coils for our ignitions.
About the load.....I doubt it would draw much in operation until it hits a "wall" and stops and then it would be pretty large.... if it is one or two components that need to be changed for this you can still draw up a circuit...maybe assuming that it uses 4-5 amps in operation and with a cut off of 10-15 amps to start and I can play with the components on my end.
To all, I really appreciate your help on this, everyone has their "niche" and mine is not circuitry....(I must have slept through most of those classes in engineering school, )
Best regards,
Chris
Old Jun 2, 2009 | 08:42 PM
needadvice's Avatar
Best regards,
Chris
I've got a circuit that should work(of course component values selected based on what the actual loads are - i think i saw in the FSM something about 0.9-1.9A?) - but it is a bit more complex than I had hoped for(see attatched). It involves use and understanding of voltage comparators and bi-stable multivibrators(flip-flops)...
I dont know what your level of component knowledge is so i am working on something simpler. Tell me this, would you be more comfortable/prefer building an H-Bridge from components(transistors/mosfets) or would you rather use an Integrated circuit?
H-bridge IC: (just an example, i havent looked to see if this specific IC would suit the application) http://www.national.com/ds/LM/LMD18200.pdf
Component H-Bridge:
also other things that may help or make this simpler for ya/me -
-do you happen to know if it is a worm drive? ie, once the valve reaches full open/close - is it held there by mechanical design, or via shorting/braking the motor?
- how does the motor sense full duty cycle as it is OEM? load sensing, time period, microswitch?
- can you take a MM to it? voltage and current during operation and at load spike will determine which component values to choose.
i think its probably likely that its worm drive or similar, but if by chance it has microswitches, or works off time period it will be much easier
BTW - dont go trying to build anything until i verify that i have a working simulation... electronics is a new hobby to me and i make plenty of mistakes - but i do have a very knowledgable group of peers to criticize my work. I'm thinking of throwing more transistors at it or trying inductance to shut the motor down via sensed current
FWIW the circuit using flip-flops and the comparator is a good starting point if you're comfortable with all that. You'll need to use a SPDT Return-to-center switch, try an LM311 comparator, and maybe CD4001 flip-flops(careful though as 12V on the 4000 series is pushing it!) also, the MOSFETS are 2 PMOS and 2 NMOS. This circuit can get stuck also - it would be wise to put a reset switch across the resistor at the comparator's voltage divider. If you chose to use 4000 series flip flops i'd reccomend good filter caps and transient voltage suppressor...
Attached Thumbnails For those with Electronic Background....-basic-h-bridge.gif   For those with Electronic Background....-motor-drive.gif
Old Jun 3, 2009 | 11:09 PM
needadvice's Avatar
Breakthrough!!!!
Chris, this is likely going to be MUCH simpler than current sensing....
I took another closer look at all the manuals -
The position sensor is built into the APV motor.
EDITAccording to the manuals is a Hall element...
position sensing is built into the motor ALREADY there is potentiometer/voltage division going on there.... with a few MM readings i can have your APV operating EXACTLY as OEM, only under your control... this is much preffered over "winging it" with load sensing i think. and it will be simpler circuit.
Sending you a PM.....
Old Jun 3, 2009 | 11:16 PM
Jon316G's Avatar
Grasshopper
So it is for the APV motor! That is what I thought!
I have an intake manifold removed so I have easy access to the motor.
I removed the APV motor and made a DIY video on how to troubleshoot various valves on the intake manifold.
So if you need anything with it let me know.
Old Jun 4, 2009 | 12:16 AM
needadvice's Avatar
highlighted is the pin i need measurements from. should be a high/low thing. V and A during motor operation and condition that triggers shutoff. btw thats page 16 from the electrical section, pin is labeled 3B and should be Red/Green colored. If I can get V&A readings from the motor i can also choose component values for you and take all the guesswork/trial&error out of it
Old Jun 4, 2009 | 12:22 AM
ChrisRX8PR's Avatar
13B-RE
The problem is that my APV is no longer connected...I've been running with all 6 ports open....
Thanks for the help.
Chris
Old Jun 4, 2009 | 01:53 AM
needadvice's Avatar
Chris
ah, well see your PMs and i can help you out more in a couple weeks. but now that i actually read the FSM - this is definately the way to go
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Olorin2
20
Mar 13, 2016 11:01 AM
MANIACman
Nov 11, 2015 10:58 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
