GReddy Type S coilovers
Old May 16, 2009 | 08:19 PM
irx08t's Avatar
Hi,does anyone have a copy of the fitting instructions/product information for these coilovers? The copy i have is in Japanese and i can't read it! Thanks
Old May 17, 2009 | 12:13 AM
dezodwest's Avatar
What type of information do you need? I have these installed on my RX-8 and the install is pretty flawless.
Old May 17, 2009 | 06:00 PM
irx08t's Avatar
AU
I have them installed already but i don't think correctly. I'm getting a rattle from one of the rear shocks,which i think could be blown cause of not setting up properly and the shock has bottomed out a bit. I also need to replace some parts on it that have been damaged by this problem.
Old May 18, 2009 | 12:23 PM
dezodwest's Avatar
There are 3 locking collars on each shock body. 2 for the spring (pre-load), and one for the shock length (ride height). If any of these weren't tightened properly, it could explain your rattle.
As to the blown shock. They take quite a bit of abuse and I track these shocks often. Are you sure the care isn't just set too low and your not bottoming out the wheel itself?
It would take a VERY hard hit to completely bottom out the shock and even then I don't know if it would blow it out that quickly. Does your car bounce a lot over smaller bumps?
I wouldn't fear the worst yet. If a shop installed them for you and you're having that many problems I would take it back to them and ask that they look at it. If your wheels are open enough, you could try to reach in and grab the collars to see if you can move them at all. Good luck!
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
jDt!
Oct 2, 2015 04:04 PM
He||hammer
Sep 29, 2015 09:40 PM
