semi confused on what peoples 1st and 2nd gear top at
Old May 15, 2009 | 02:15 PM
heyguy22's Avatar
i have an 04 rx8 vr gt ive had it for a few years now just hit 30k anyways was watching peoples youtubes video and i was seeing 1st topping at 38-40 and 2nd topping at 62-66 well my car is bone stock and my 1st tops at 45 and 2nd is 77 was just curious on what you guys are getting
Old May 15, 2009 | 02:18 PM
ferg's Avatar
i get like 50 in fist
Old May 15, 2009 | 02:27 PM
Eelfinn_Ty's Avatar
I'd guess that your 8 has an automatic transmission. The 04's w/ automatic transmissions have a little different engine in them(4 intake ports vs 6), and don't make as much power.
from wikipedia...
"4-speed automatic tuned to 141 kW (192 PS; 189 hp) in some markets, while the U.S. automatic is stated to deliver 158 kW (215 PS; 212 hp)."
Old May 15, 2009 | 02:30 PM
ferg's Avatar
yeah the AT is not a race car MT is
endowdly's Avatar
Guppies? Anyone?
It has nothing to do with power. It has everything to do with gear ratios.
Old May 15, 2009 | 02:31 PM
endowdly's Avatar
Guppies? Anyone?
The MT has higher ratios than the AT and should top out at lower speeds.
Old May 15, 2009 | 02:32 PM
ferg's Avatar
its just a car, go drive around j/k lol its alot more then a car i know
Old May 15, 2009 | 02:34 PM
heyguy22's Avatar
Noooo i dont have an auto rx8. mt all the way
Old May 15, 2009 | 02:41 PM
renesisgenesis's Avatar
mod edit
well, unless someone before you put in a setup with a different final drive ratio(I have never heard of a lower ratio though...), then clearly you have non oem tires with a larger diameter than stock. Stock diameter tires give 40 mph at 9000 in first and about 66 mph at 9000 in second, and about 90 mph at 9000 in third.
Old May 15, 2009 | 02:48 PM
JinDesu's Avatar
went back to srsly broke
Now I know I have an auto, but I could have sworn the MT 3rd gear topped out at 100+?
Old May 15, 2009 | 02:49 PM
YaXMaNGTO's Avatar
It's a Cavalier
Dude! You got one the special edition 2004 RX-8's with the 11,000 RPM redline Renesis! They only made 5 and all of them were Velocity Red. The other 4 are in Japan and are locked away in the garages of rich Japanese millionaires.
So lucky.
Old May 15, 2009 | 02:51 PM
heyguy22's Avatar
hrmmm i put a set of cooper zeons all way around they are 245-45-18 wheels are stock but compared to stock tires i have more traction grip and car seems a bit quicker
Old May 15, 2009 | 02:53 PM
mod edit
Haha dude you need to learn to think a little bit...
stock tires are 225/45, so going to 245/45 will OBVIOUSLY mean a larger diameter....
wow
Old May 15, 2009 | 02:55 PM
mod edit
no no trust me it's 90. in 3rd gear, engine speed/100 = car speed.
Old May 15, 2009 | 03:00 PM
JinDesu's Avatar
Gotcha, thanks.
Old May 15, 2009 | 03:01 PM
heyguy22's Avatar
haha im retarded just walked out to garage 225-45-18 didn't think the tires were that small
Old May 15, 2009 | 03:03 PM
heyguy22's Avatar
oh yeah im also new to the forums nice to meet everyone.
Old May 15, 2009 | 03:10 PM
Brettus's Avatar
Boosted Kiwi
US spec 90 - JDM 100
https://www.rx8club.com/rx-8-discussion-3/speed-3rd-gear-103670/
Old May 15, 2009 | 03:15 PM
Brettus's Avatar
Boosted Kiwi
wow
and larger diameter means you will be going faster ....................
BUT your speedo does not know you have bigger tyres on and only reads wheel speed . Which for a given engine rpm will remain the same .
So - the max speed in each gear as read by the speedo stays the same no matter what tyre size you have on ..................................
Old May 15, 2009 | 03:16 PM
ferg's Avatar
yeah its much larger
Old May 15, 2009 | 03:21 PM
YaXMaNGTO's Avatar
It's a Cavalier
wow
You're asking him to think a little?
The difference between going from a 225/45-18 and a 245/45-18 results in ONLY a2.7% difference in rolling circumference, NOWHERE NEAR the error he says he's seeing...
It also means that by going to a LARGER tire, the speedometer will actually read 2.7% SLOWER. When the speedometer reads 60mph, you're actually going 61.6mph.
Why don't YOU think before calling somebody else stupid?
I do realize he came back and said the tires were the stock size.
Old May 15, 2009 | 03:25 PM
YaXMaNGTO's Avatar
It's a Cavalier
So - the number on your speedo stays the same no matter what tyre size you have on ..................................
Brettus, it absolutely does make a difference what size tires you have.
Here's a handy calculator for it
http://www.miata.net/garage/tirecalc.html
Old May 15, 2009 | 03:30 PM
PSTNLSS's Avatar
The Former PSNTLSS
So lucky.
Woah I was told I was the only US one!!!! ugh
dam
But to answer the whole semi confused
MT for me redlining/fuel cut off for first is about 39mph ive seen 42 once.
Second Gear, the few times I've redlined first to redline second I got like 69? I believe it was.
But if you have an AT you may see high 40's to redline though I can not speak for sure
Also make sure the youtube videos are in mph not KPH
Old May 15, 2009 | 03:34 PM
YaXMaNGTO's Avatar
It's a Cavalier
Unless you changed the gearing, there's no ******* way you're hitting 77 mph in 2nd gear, so either your speedometer is waaaaaaay off or you're pretty much on crack.
Oh, and welcome to forum!
Old May 15, 2009 | 03:40 PM
YaXMaNGTO's Avatar
It's a Cavalier
65mph = 105kph
Good thought, but he would be telling us he's shifting out of 2nd at 105
Everybody look at the R&T data panel under "Drivetrain"! Learn a little about your car!
http://www.roadandtrack.com/assets/d...2003171557.pdf
