how to get the broken maf screw out?
Old May 14, 2009 | 04:04 PM
yes i know i fudged up
the maf screw broke off in half, i didnt even try to overtight it, i was trying to get it back out and it broke...
anyway, i took the tube to some auto place and they said they cant do it and suggest i go visit some machine shop.
question is , is that true ? if yes how much would it cost ? is it even possible to get a small broken piece like maf screw out ?
or i better off just buy some small drill bits and try to drill it out myself ?
Old May 14, 2009 | 04:17 PM
myriadshalaks's Avatar
rot8ing
how far down is it broken? stock screw or for an intake?
a drill bit is going to have to be crazy small to get in there. i don't think there's even a back out bit that'll fit in there.
maybe a high pressure air hose from underneath.
or, just rip it off and buy a new maf.
how did you break it anyway? too many muscles?
Old May 14, 2009 | 04:38 PM
Brettus's Avatar
Boosted Kiwi
You're screwed
Old May 14, 2009 | 04:40 PM
how the hell did you do that NY?!
got a picture?
Normally I would say take a drill to it but if I remember correctly, that is a tiny *** screw.
04RX8man's Avatar
Rotary Powered Countryboy
yeah possibly try drilling it out worse comes to worse and u break it u just have to buy a new MAF anyway so it's worth a try!
Old May 14, 2009 | 05:09 PM
Jon316G's Avatar
Grasshopper
Can you break enough of the bolt head off to just remove the MAF assembly and then use vise grips to un-thread it from the pipe?
Drilling may not be a bad idea to simply finish breaking the head off.
Don't need to drill into the threaded area.
Just a thought.
Old May 14, 2009 | 05:57 PM
I think Im screwed
I got a new hks intake from CRH (just for the hell of it)
the MAF screw was the one that came with Mazdaspeed intake. I totally forgot that its a tiny *** bigger than the original stock intake MAF screw(thats why they give it to you).
I was about to finish the install, MAF was the last step, then I got over excited and tried to force that screw in and .... I was like hmm wait, holy ****, then I tried to back it out but it was too late. the one of the head broke off.
I took it to a machine shop before, he tried to remove it but then failed, it was too tight, and there is no space there to drill.
so yep, Im fucked
Original MAF screw on order coming in tomorrow(I lost the original one), Gonna do it the ghetto way ------------------ TAPE THAT **** !!!!
Will post pics up later ... just let me feel sad for a while cuz I screwed my 500+ bux purchase with a tiny *** screw that probably worth less than a buck ...
Old May 14, 2009 | 06:30 PM
pix!!!
Old May 14, 2009 | 06:41 PM
shazy's Avatar
Pics or it didn't happen!
Wait. On the oem intake (which is what I have) is it the that square piece with a weird tube going into the top of the intake and only has 2 small screws?Or is that the Vfad?
Old May 14, 2009 | 07:17 PM
rot8ing
^yeah, that's the maf (mass airflow sensor). the square thing.
Old May 14, 2009 | 08:14 PM
aww, Im crying.
pic up later ...
Old May 14, 2009 | 08:20 PM
Jon316G's Avatar
Grasshopper
Might sound crazy, but try using a strip of sandpaper over the broken bolt.
Then use your finger to push down and turn counter-clockwise.
The idea is for the sandpaper to (hopefully) have enough grit to latch onto part of the bolt and you'll be able to spin it.
As long as its not too tightly installed.
Old May 14, 2009 | 09:08 PM
the problem is that its tooooooo tight ...
I show it to my father, he said its going to be hard, but its possible to get it out.
will try his method tomorrow ... *shurgs*
Old May 14, 2009 | 09:16 PM
Brettus's Avatar
Boosted Kiwi
One way of getting a small screw out is to get a hacksaw and cut a screwdriver slot into the top of the screw - does not sound like you have enough meat in it to do that however .....
Old May 14, 2009 | 09:17 PM
Jon316G's Avatar
Grasshopper
I was thinking the same thing.
Use a Dremel to cut a slot and use a flathead screwdriver.
Would have to be a thin cutting bit.
Old May 14, 2009 | 10:56 PM
tried that at the machine shop, doesnt work, wont even budge
gonna do the drill at the center method ... gonna get some tiny *** drill bit tomorrow morning ... wish me luck
Old May 15, 2009 | 12:23 PM
04RX8man's Avatar
wow we need pics NOW!! haha...good luck
Old May 15, 2009 | 12:38 PM
I can't believe we don't have pics of this epic failure....
(sorry Ny, couldn't resist...)
Old May 15, 2009 | 01:10 PM
04RX8man's Avatar
^haha he could have avoided us all knowing of the EPIC FAILURE if he only would have SEARCHED!!!!! HAHA. had to do it
Old May 15, 2009 | 01:17 PM
Socket7's Avatar
ಠ_ಠ
meh. Just wrap the whole mess up in duct tape.
Problem solved!
Old May 15, 2009 | 01:18 PM
^^^ +1
Old May 15, 2009 | 01:19 PM
TheWulf's Avatar
My 8 looks like a Smurf
You're screwed
Old May 15, 2009 | 01:24 PM
staticlag's Avatar
The Professor
Have you tried using a tap?
If its a metal-metal connection you can just drill a tiny pilot hole and re-tap the hole
Old May 20, 2009 | 09:19 AM
rot8ing
is it out?
Old May 20, 2009 | 01:35 PM
kersh4w's Avatar
Hit & Run Magnet
thats what she said
