POWER!!!!! problems!!!
Old May 14, 2009 | 07:44 AM
Chris's Avatar
Turbo Member
I just changed the alternator because two shops told me that it was bad and when I checked it with a amp/volt reader it was reading in the low 12's which leads me to believe it was bad. So I changed it and the new alt reads at high 14's. I can not keep the car running, anyone know what I need to do. I put it on the charger for now to see how that goes. Anyideas would be great at this point
Old May 14, 2009 | 08:54 AM
EDZRIDE's Avatar
2005 White GT
Normal charging rate is 14.25 volts.
Old May 14, 2009 | 01:10 PM
Chris's Avatar
Turbo Member
Yeah I know what the normal rate should be
Old May 14, 2009 | 01:22 PM
1) Your battery could be dead.
2) Remember, when the ECU looses power it is re-set.
You need to drive it for a couple of cycles before the car will idle properly.
Old May 14, 2009 | 01:26 PM
endowdly's Avatar
Guppies? Anyone?
If your alt is pushing >14.25 V under load...
...you need a new alt.
Old May 15, 2009 | 02:00 PM
Chris's Avatar
Turbo Member
New battery and new alt and runs great!
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
