120,000 miles on my engine
Old May 13, 2009 | 03:09 PM
TALAN7's Avatar
been having stalls and rough idle when starting that went away after 30-40 seconds. I replaced the plugs and coils but it came back so I took it to a rotary mechanic. Short story, he did a coolant pressure test, I'm getting water in my engine. Need a new one.
Are there any temporary fixes for this? Had to ask.
Old May 13, 2009 | 08:41 PM
How do you know you don't have a bad radiator?
Check to see if there is water in the oil.
Old May 13, 2009 | 09:29 PM
Old Rotor's Avatar
There is a tool that you use for the exhaust in coolant test. It uses a blue liquid that when exposed to exhaust gas turns yellow. Ask what test he did?
Old May 13, 2009 | 10:40 PM
Ahh, hey its you !
that sucks, You came a bit late, Mazmart was running a crazy promotion, 1900 bux "brand new Reman engines" + Shipping (about 2-300 bux extra.)
temporary fix? well, the motor is all fudged up anyway, u can just pour some stop leak crap into it and see if it helps ...
Look into your coolant bottle, see if u can see any oil flowing around ?
If his radiator leaks Im pretty sure he can see it on the floor
Probably just Cooling system pressure test.
Its a pump thing that u build pressure in the system, and wait 10 or 20 minutes or something, if the pressure stays, its good, if it drops. no good.
Old May 13, 2009 | 10:48 PM
Alexb's Avatar
desperately needs a drop
How much are those engines regularly nycgps?
Old May 13, 2009 | 11:14 PM
2800 or more. depends on the condition + shipping.
Old May 14, 2009 | 10:25 AM
TALAN7's Avatar
He did a pressure test to the radiator or whatever and said once he started it after a whole lot of white smoke came out until the water burnt out. Was quoted about $4000 for reman
Old May 14, 2009 | 10:42 AM
Natey's Avatar
Playing Well
Sounds like the coolant seals are toast.
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
kaboshe
Jul 17, 2015 03:14 PM
