Spacer: I need real input
Old May 13, 2009 | 11:16 AM
Thumbs up Spacer: I need real input
Yes I have read the other threads about spacers.
Okay guys, I am getting aftermarket wheels (Tenzo Type M) with the correct offset but I am also doing my stockers in Graphite and I would like to use 10-15MM spacers for DD as I don't plan to run my new rims daily.
But, I want to know if there are really any problems running them. I don't want opinions on what your friend said, etc. etc. If you have a constructive opinion post them. Of course I am talking about quality hub centric spacers.
Old May 13, 2009 | 11:29 AM
kersh4w's Avatar
Hit & Run Magnet
for DD, spacers are fine.
i wouldnt drag race or road race with spacers though.
Old May 13, 2009 | 11:50 AM
I'm no engineer but as long as they are bolted up tight I don't see how they are any different from wider wheel with a diff offset. It would be easy enough to have them welded as well. Just thinking, I really like the look of the stock wheels and I don't want my new rims getting beat up.
Old May 13, 2009 | 12:51 PM
rotary.enthusiast's Avatar
The Local Idiot
The major issue with spacers vs lower offset wheels (IMO) is that the spacers take up wheel stud that is no longer engaged by the lugs, so the force of the torqued on lugs is spread out across a much smaller area of the studs.
Old May 13, 2009 | 01:09 PM
Even the spacers that bolt to the factory studs?
Old May 13, 2009 | 01:57 PM
The Local Idiot
Yeah. Think about it for a minute... if you take the stock wheel and move it out 15mm, then the lug nuts are going to seat 15mm further out, and engage 15mm less of the wheel studs. It doesn't matter what's behind the wheel.
Old May 13, 2009 | 02:01 PM
cjkim's Avatar
^noob
there are spacers WITH built in studs
honestly, as long as you get quality spacers you should be fine.
Old May 13, 2009 | 03:27 PM
The Local Idiot
Sure, but those are way thicker than the 10-15mm he is looking to push them out. You're looking at an inch or more for those types of adapters.
EDIT: You might be able to find a set of spacers that comes with lugs that extend further past the face of the wheel in the size you're looking for
Old May 13, 2009 | 04:08 PM
kersh4w's Avatar
Hit & Run Magnet
15mm, with studs, no sweat
http://www.hotlapmotorsports.com/pro...2&idproduct=26
10mm, with extra long studs, little bit of sweat
http://www.modernperformance.com/eib...ds-p-1700.html
Old May 13, 2009 | 04:10 PM
Thanks for the imput guys, I'm looking at the Kics.
Old May 13, 2009 | 04:27 PM
The Local Idiot
Those both require the removal of the stock studs though, right? He only wants the spacers for his stock wheels... his new wheels have the correct offset already. Or am I mistaken here?
Old May 13, 2009 | 04:47 PM
Yeah the H&R ones are the kind I'm looking at that bolt to the stock studs.
Old May 13, 2009 | 05:31 PM
dwdgsi04's Avatar
:D
You are mistaken. They have small lugnuts that bolt onto the stock studs. And then you use whichever lugnuts you wnt to bolt your wheels on the studs that are attached to the spacers themselves.
Plus if you're worried about 10mm spacers lugs causing interference, if you look at the back of rims there are divets built into it where the protruding stock suds can fit.
Attached Thumbnails Spacer:  I need real input-dscf0144.jpg   Spacer:  I need real input-dscf0145.jpg
Old May 13, 2009 | 05:37 PM
dwdgsi04's Avatar
:D
BTW, if you are interested in 15mm spacers, I am selling the ones I purchased and only test fitted with my rims. They caused the wheel to stick out further than I wanted so I need to get rid of them now. Never drove with them. PM me if you're interested.
Old May 13, 2009 | 06:05 PM
pdxhak's Avatar
Official Post Whore
Why not just order the wheels with the width and offset you are looking for?
Old May 13, 2009 | 06:10 PM
dwdgsi04's Avatar
:D
Well, he's using his stockers as DD wheels, and that's the offset he's trying to correct.
Old May 13, 2009 | 06:20 PM
Ever Hernandez's Avatar
Rx8_4eVeR
Go with 15mm to be on the safe side. I put a 10mm-also Kics-on the front and still needed another 3mm so the wheel wouldn't wobble. I guess you could also notch the original studs. but 15mm should take care of things nicely. Good luck
Old May 13, 2009 | 09:33 PM
Yea, I was thinking 15mm too. Thanks. I just want the best quality ones I can find.
Old May 13, 2009 | 09:56 PM
dwdgsi04's Avatar
:D
Off-topic, what part of SA are you in 9K?
Old May 13, 2009 | 10:07 PM
Olmos Park and I work in the Medical Center.
Old May 13, 2009 | 10:29 PM
dwdgsi04's Avatar
:D
Oh nice, I used to live over in Medical center, Promintory Pointe apts. Was just curious.
Old May 13, 2009 | 10:30 PM
Cool, I was born in Cali so i've been your way.
Old May 13, 2009 | 10:40 PM
dwdgsi04 - You need to come out to the Autocrosses in Marina one of these months :D
I have yet to see you there... You know you want to
Old May 14, 2009 | 10:03 AM
gh8st's Avatar
STiMPACK
i'm running 25mm all around with rims that are stock offset and they're fine for dd.
[edit]
if you run 15mm spacers, the stock studs will hit the back of the rims.
Old May 14, 2009 | 10:25 AM
ODDDOOD's Avatar
The DOOD abides.
Who makes the ones you are using?
I have been wanting to get a proper set for my OEM wheels but was unsure of how far I could go before hitting the fender. If you are running the GF210's on OEM struts, we probably have near identical drops. Did you have to roll the fenders?
Thanks in advance!
