Feeler: Boston Acoustic Amps
Old May 10, 2009 | 12:04 AM
WVBoosted8's Avatar
I have a Boston GT-22 amp I am using along with a GT-42. The 4 channel I installed last week and decided to go in a different direction.
I must sell both amps in order to redo my setup so I will let both amps go for 325 + shipping. Shipping shouldn't be more than $40 or so. Even through discount and refurbished dealers you can't get this combo for less than 459.99 and they are all backordered.
This is more than enough power for most systems and almost ALL component sets.
BOSTON GT-22 AMP $125 + Shipping
# 2-Channel High Current Amplifier
# RMS Power Rating @ 14.4VDC:
* 100 watts x 2 chan. @ 4 Ohms
* 175 watts x 2 chan. @ 2 Ohms
* 350 watts x 1 chan. @ 4 Ohms
* 500 watts x 1 chan. @ 2 Ohms
# RMS Power Rating @ 12.6VDC:
* 75 watts x 2 chan. @ 4 Ohms
* 135 watts x 2 chan. @ 2 Ohms
* 270 watts x 1 chan. @ 4 Ohms
* 400 watts x 1 chan. @ 2 Ohms
# Adjustable input sensitivity
# Recessed RCA Jacks: provides clearance is tight mounting locations
# Advanced cooling allows varied mounting positions
# Adjustable feet for varied mounting surfaces
# Security cover protects control settings
# Continuously variable crossover and Q-factor settings
# Highpass, Lowpass, or Bandpass configurable
# Q-Tune™ technology seamlessly transitions rear bass to the front sound stage
# The GT's DPS™ (Dynamic Power System™) ensures high efficiency and ouput stages, increased power with lower impedance and maximum dynamics and transient response
# Variable crossover points for exact integration of speakers and subwoofers
# Dimensions: 308mm L x 225mm W x 57mm H
BOSTON GT-42 AMP $200 + Shipping
* 4-Channel High Current Amplifier
* 2 Ohm Mono Stable
* Advanced cooling allows varied mounting positions
* Adjustable feet for varied mounting surfaces
* Screw-down security cover protects tuning controls
* Terminals accept bare heavy-gauge wire
* RMS Power Rating:
o 14.4VDC:
+ 100 watts x 4 chan. @ 4 ohms
+ 150 watts x 4 chan. @ 2 ohms
+ 300 watts x 2 chan. @ 4 ohms
+ 450 watts x 2 chan. @ 2 ohms
o 12.6VDC:
+ 75 watts x 4 chan. @ 4 ohms
+ 120 watts x 4 chan. @ 2 ohms
+ 220 watts x 2 chan. @ 4 ohms
+ 350 watts x 2 chan. @ 2 ohms
* Adjustable input sensitivity: 0.2 - 5 V
* Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
* Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
* Variable Q Control: 0.7 - 1.2
* Power and Safe LEDs
* Recessed RCA Inputs allow clearance for tight mounting locations
* Optional subwoofer level control not included
* Dimensions: 22" L x 9" W x 2-1/2" H
Here is a pic of everything installed
Old May 10, 2009 | 04:50 PM
WVBoosted8's Avatar
Noone needs some nice amp! ?
nadodave
Aug 28, 2019 05:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
