Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Running Light Install
Old May 9, 2009 | 03:54 PM
Vanguard's Avatar
So I decided to improve the front end of my 8 with some Porche style LED running lights.
First step, removing the bumper.... easy part was locating and removing the bolts and secring plugs, harder was disconnecting the fogs and headlight washer system, but only because access was tight
This view shows the inside of the bumper
I decided to install the LED's running across from the centre of the Fogs, like the new Porche Cayman. By themselves, there was little to attach them to, so I was going to need some supports.
this is the appeture from behind
so I made up some simple bent wire supports to go horizontally from the fogs to the bumper
Next, I sprayed them satin Black to blend in with the Oil coolers so you would't notice them once installed and Epoxy'd them in
Next step was to epoxy the LED's to the support and the Fog. Initially just put a little on to verify position and angle
After trial fitment and I was happy, I added extra epoxy to make the lights securely attached. I took power from the Park lights, so I can have the running lights on without the mains.
And here they are.. fully installed and functional
Old May 9, 2009 | 03:55 PM
myriadshalaks's Avatar
rot8ing
interesting. i like it. very well done.
Old May 9, 2009 | 04:33 PM
mscamp02's Avatar
Blue Bullet?
I like it.....havent seen it before either
Old May 9, 2009 | 04:35 PM
mscamp02's Avatar
Blue Bullet?
Get some pictures of it at night!
Old May 10, 2009 | 08:11 AM
heyarnold69's Avatar
Rotary wanabee
Dear sir,
You are a genius!
Old May 11, 2009 | 02:57 PM
Vanguard's Avatar
LED's at night
Sorry for the delay....
With just running lights
and with full lights
Old May 11, 2009 | 06:09 PM
pdxhak's Avatar
Official Post Whore
Just need some v-leds for the running lights inside the headlight unit What type of epoxy did you use? 2 part 5 minute cure?
Old May 12, 2009 | 02:08 AM
Vanguard's Avatar
Yup... epoxy used was 2 part - 5 minute cure
Old May 12, 2009 | 06:40 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
That looks real nice! Great job! I got a couple of questions though:
1) Where did you get the lights?
and
2) How do you think it would look if you had a light bar long enough to cover the entire opening? (such as eliminating the fog lights, or for those who may not have fog lights)
Old May 13, 2009 | 05:31 AM
Vanguard's Avatar
longer LED's
The Lights I got from a local store... I'm sure your could get longer ones... just search the net, there are a plethora of them....
As for how it might look... quick Photochop and ... voila
Attached Thumbnails DIY: Running Light Install-dscf2435-2.jpg
Audio Concepts ATL
Sep 26, 2021 01:59 PM
SUKIEE
Oct 9, 2017 09:41 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
