will this work to clean the carbon from my engine?
Old May 7, 2009 | 06:40 PM
elysium19's Avatar
there's really no way to tell for sure. if you compared the major ingredients it would tell you something, but i doubt either one tells you the chemical components.
Without that info, I would say:
positive: it *probably* does basically the same thing. Carbon is carbon, however deposits of hydrocarbons from gasoline are not the same as those from oil, as found in our engines.
negative: it definitely was not specifically formulated for rotaries. Also, buying a can of seafoam or zoom-zoom cleaner is pretty inexpensive, and you know it works. So that's probably a better idea...
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Ccrosskno21
Jan 9, 2016 05:43 AM
AussieGray
Jul 16, 2015 03:58 AM
