HELP!!!...Exhaust manifold Clamps
Old May 7, 2009 | 08:34 AM
Dremd911's Avatar
Dre's 8 "I started Late"
Hello all,
so here is what happened...I was driving my 2004 auto Rx8 yesterday and i noticed a noise coming from the front right of my car when I hit the brakes. Soon after before i made it a mile home my car was rattling only in drive and fine in park and neutral. So i automatically assumed it was the right engine mount, because i read this bulletin already. I printed the bulletin, left at dealer with keys and received a call at 9:15 a.m. Tech dept. doesnt open until 9:00 a.m....so aparently my car was looked at for 15 minutes and the bulletin was ignored. I was told that the manifold or shields on the exhaust needs 4 clamps 2 small and 2 bigger ones as it is loose and thats the noise i am hearing. $120- also, my brakes need to be spit shined with lube and all that good stuff so they dont stay closed, due to water getting in there....
My question to you guys is BS or are they telling me the truth...car has 50k miles
Old May 7, 2009 | 09:35 AM
Dremd911's Avatar
I made the service manager send an email...heres a copy of what needs to be done...ANYONE ENCOUNTERED THIS...ive searched all over and can't find JACK
We checked rattling noise found it to be exhast related need to reposition ans replace 4 clamps , also frt calipers are hanging up calipers ok slides and pins binding recommend service frt brakes pads and rotors ok at this time .
30K 499.00
EXHAUST REPAIR 75.00
BRK CALIPER SERVICE 129.00
Old May 7, 2009 | 05:34 PM
Jon316G's Avatar
Grasshopper
I've seen a few caliper pins seized because the boot slid off.
I had it happen to one of my calipers and it wore the pad behind the rotor to the bare metal and actually dug into my rotor.
Since that pad didn't have a wear indicator tab, I didn't hear anything until the pad was completely worn.
I ended up taking the pins out, cleaned and greased them, and zip-tied the boots once the pins were reinstalled so they would slide off again.
So its good that they are taking care of that now.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
Evan Gray
Sep 26, 2015 12:30 PM
