HELP!! Weak Acceleration Under 4000 Rpm
Old May 6, 2009 | 10:00 PM
BrightEyes's Avatar
Styrofoam Boots
hey there,
first of all im a mazda technician (have been for a loooong time) and after checking this particular RX-8 i could not find the cause of the problem.
heres the problem
i give it gas upon taking off, nothing heavy, the same amount of throttle i would give it when starting from a stop sign, and its dragging along, truly terrible, but after 4000 rpms, its fine.
i checked compression, sparkplugs, wires, the catalytic (incase it was clogged up), fuel pump, pretty much everything,
and nothing seems to make it better.
please tell me if you have had a similar problem or know someone who has, what the cause of the problem was. Or if you have any idea what could be causing this.
thank you
Old May 6, 2009 | 10:31 PM
The car idles fine so its not a vaccum leak?
Is it possible the parking brake is rubbing but the brake light is burn't out?
How about stuck calipers? Drive it a half block and check the discs.
It will be hotter than a pistol.
Old May 7, 2009 | 08:35 AM
BrightEyes's Avatar
Styrofoam Boots
ill check but the thing is, after 4000rpm its normal, acceleration is fine.
the problem only occurs before 4000-ish.
Old May 7, 2009 | 08:38 AM
alnielsen's Avatar
Did you try the leading coils? They weren't on your list.
Old May 7, 2009 | 09:38 PM
BrightEyes's Avatar
Styrofoam Boots
ill try that tomorrow, ill change em out and see, thanks
Old May 8, 2009 | 12:04 AM
Switched plug wires?
Old May 8, 2009 | 05:25 PM
BrightEyes's Avatar
Styrofoam Boots
the two leading coils did it, the car runs like new
thanks a lot for your help.
mdl0209
May 23, 2019 05:46 PM
Michael Bryant
Oct 12, 2015 03:07 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
