Greddy Infometer Touch - Installed
Old May 5, 2009 | 11:23 PM
JohnnyFamous's Avatar
Greddy Infometer Touch version 1.04 first impressions.
WTF is all this?
How does this work?
Oh $hit!
This thing is sweet
Installation is very easy gets the power the OBD2. When setting the Infometer to connect to the ECU. It wants you to select a “make” it list all JDM car makers but Mazda so I pick “ISO CAN”.
This is what the unit can read.
RMP
SPEED
IGNITION TIMING (DEG)
THROTTLE (V)
THROTTLE (%)
WATER
INTAKE TEMP
AIR FLOW (G/S)
AIR FLOW (%)
INJECTOR (MS)
INJECTOR (%)
A/F (but needs an F-manager to see this) – Maybe - there are values you can change. Default displays 5.3 and does not move. In the settings menu under A/F you can pick "conversion 0V' (5-20v), "conversion SV" (5-30v)
GEAR POSITION
POWER (HP)
(This is to manage your MPG)--
TRIP
E INSTANT
E AVERAGE
E TOTAL
E SECTION
FUEL TOTAL
FUEL COST
--END
FULE SYS (OPEN/CLOSE)
FUEL SYS 2
S TERM FT (%)
S TERM FT R (don't know what this is. Its not in the manual, displays -2, -1, 0, +1, +2)
L TERM FT (%)
02 V (V)
BATTERY (V)
OUTSIDE TEMP
ANALOG V
There are maybe 2-3 more signals you can view I don’t know them off the top of my head. I am going from the instruction booklet I check off the ones I’m not able to view. I will post the ones I’m missing. There are 83 pages in Chinese and 11 pages in English. English section goes over basic install nothing technical. You can view 6 signals at once and each one displays a peak value.
I will post more as I play around with it and try to find more information. Pictures will follow as well
Old May 6, 2009 | 07:36 PM
Old May 7, 2009 | 12:15 AM
moneys, and link?
Old Sep 1, 2009 | 06:25 AM
Soloseven's Avatar
Thanks, your detailed post gave much more info than the Greddy site. I will pick up the Infometer Touch. What problems have you had with the Infometer Touch? And which signals where you not able to display? Why Greddy hasn't tested a Infometer Touch with a RX8 is a mystery. They have tested the Mazdaspeed 3, Mazda 3,Mazda 6, including the Mazda 5.
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Jelliott5384
Oct 26, 2016 05:15 PM
jDt!
Oct 2, 2015 04:04 PM
