milesprwr
05-04-2009, 02:19 AM
Recently installed a new set of spark plugs. I took pictures of the plugs I pulled with ~37.5K miles on them. For your viewing pleasure:
http://lh5.ggpht.com/_Qpjw19strK4/Sf6VaYa1lpI/AAAAAAAAARM/kKt0t1SMFU0/s640/IMG_0828.jpg
http://lh5.ggpht.com/_Qpjw19strK4/Sf6VZsGgEII/AAAAAAAAARE/rgs2Qvj4rek/s640/IMG_0827.jpg
milesprwr
05-04-2009, 02:36 AM
Hehe thanks - here's a link to a recent post and could use some input as well!
http://www.rx8club.com/showthread.php?p=3002153#post3002153
rx8sergio
05-04-2009, 03:20 AM
never mind i guess its normal...i pulled mine at 45k and they were much cleaner than that thou
souljamcdiddy
05-04-2009, 06:06 AM
I pulled mine at about 43k they looked the same, with the exception of one was broken. When I took the wires off, one of the plugs came off with it. No force required it was that brittle.
maximyuryev
05-04-2009, 09:56 AM
I pulled mine out to check on them about a week ago, first time ever doing so, and all of the plugs are round all the way around, like the second picture. is that normal?
Atilla
05-04-2009, 10:25 AM
crap...looks like mine are probably gonna be worse...44k currently :icon_no2: I've been laggin'....
shaunv74
05-04-2009, 11:31 AM
That is not normal. It looks like someone gave you only either the leading or trailing plugs (I forget which). You should get a new pair of whichever one's you're missing and swap them out ASAP.
DarkBrew
05-04-2009, 11:55 AM
I posted these pictures in Nov 2007. 48,000 miles Leading plugs had been changed in a previous recall.
http://www.rx8club.com/showpost.php?p=2154248&postcount=1
These are pretty normal looking for a rotary.
looks like maybe a bit of high-speed glazing. There's a bit of crud on the far side of the center electrode on the leading plug. Can't tell for sure but appears somewhat metallic. I'd probably replace these.
Razz1
05-04-2009, 07:51 PM
the thickness is from the car running pig rich.
See the back? that shows you it still is running rich. It came from idlig the car before you changed the plugs.
The light tan reveals that you car is still capable of running correctly or you were just recently running the piss out of it and it hasn't had the chance to turn black yet.
milesprwr
05-04-2009, 08:41 PM
Interesting - is it normal than for the RENESIS to be running rich? Just drawing from the handful of comments here stating that these plugs look normal for the amount of miles on them.
mazdaverx7
05-05-2009, 01:44 PM
i dont think the plugs look bad at all. a little buildup but for a rotary, thats normal. remember, the engine uses oil in the combustion chamber for cooling and for lubrication. oil burning can really kill a set of plugs, as can high engine temps. i woud feel comfortable replacing those without hesitation but i say that your engine is running well, perhaps a bit on the rich side..better than being too lean:)
