My 2008 Corvette 0 to 60 and 100
Old May 3, 2009 | 07:56 PM
LostAngel's Avatar
Well I finally had some time to start retuning my car after I got the headers on...my tuning device allows me to log a bunch of settings...including timestamps, rpm, speed, spark advance, and knock retard, MAF airflow.
I decided to do a 0-60 and 0-100 (on a closed track..) log.
Attached is a pdf of the run. It is based in excel, and I have added a 2nd column called 'edited time'. Since the log started 3.389 seconds before I actually started moving, I simply made a formula that subtracted 3.389 seconds from the original time so I can get a timestamp starting at 0:00:00:00 right as I started going. I applied this to all rows.
Here is some info on the car at the time of doing this log
2008 Corvette 6-speed manual
1/2 tank of gas
197 degrees coolant temp
31 PSI in rear tires
Windows Up
Targa Top ON
mods:
SLP Loudmouth 1 exhaust
Vararam Ram Air Intake
Throttle Body Spacer
LG Pro Long Tube Headers with 32 inch long primaries...1 3/4 inch diameter piping in the primaries
High Flow Cats
LG X-pipe
As you can see in the logs...I launched from around 4400rpms. I popped the clutch, but gradually applied the gas so I didn't get a ton of wheelspin..still heard my tires spinning up till
According to this, my times are:
0-60 - 3.457 seconds (page 15)
0-100 - 8.309 seconds (last page)
I'm going to try and get it to a strip to get a timeslip soon.
File Type: pdf
Old May 3, 2009 | 08:09 PM
8 Maniac's Avatar
Senior Member
I'd rather see a video of it doing that
Old May 3, 2009 | 08:15 PM
LostAngel's Avatar
I'll try and get videos soon...i've had a couple requests for hearing my headers
Old May 3, 2009 | 09:49 PM
YaXMaNGTO's Avatar
It's a Cavalier
What are you putting to the ground? Because, you can't rationally say your car went 0-60 in 3.5 seconds unless you're up around 440-450 rwhp and you have drag radials.
A 3.5 0-60 and an 8.3 0-100 in a Vette lands you about an 11.8 at about 121 mph quarter mile. Your car can do that with those mods?
I'm just saying, the way you're measuring it might not be the most accurate.
Old May 3, 2009 | 10:05 PM
LostAngel's Avatar
Haven't dyno'd it but other cars with the same mods are getting around 430-440RWHP
These are the 'top of the list' showroom stock people on the corvetteforum I belong to
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
11.80 @ 118.82 - Gmrulz - 08 A6 Z51, Npp - (3482)
12.10 @ 117.60 - Dingrao - 08 A6 - (3567)
12.15 @ 115.59 - Old Goat - 09 A6 2.73 - (3712)
The headers I have, are worth 30-35RWHP...and around 35-40 torque
The vararam intake I have is known to cut .3 seconds in the quarter mile with just the intake (backed up by multiple people that run it, along with other magazine articles).
I usually get the most 'thats bs' on my intakes gains...below is a screenshot from an article in GM High Tech magazine.
I hope to get to the strip sometime soon to get a slip.
Old May 3, 2009 | 10:25 PM
jones75254's Avatar
Thats perty fast partner. U saying you ran 3.4 w/ street tires?? Man that is really hard to believe that u could pull that time feathering the clutch till it hooked, takes too much time. No doubt its fast as hell but that seems a lil low. But hey, im sure its pretty close anyways. get those vids posted so we can c that beast.
Old May 3, 2009 | 10:30 PM
YaXMaNGTO's Avatar
It's a Cavalier
Showroom Stock
That's cool you're going to take it to the strip.
Funny thing is, I bet I know "Old Goat" on that list. He used to have an 11 second bolt on only GTO until he traded to an A6 Vette. He got a lot out of his setup, and was at the top of our Bolt On list. That 12.15 will be an 11.xx soon.
11.71 with an M6? Holy ****. That's bangin' em. I guess that your 3.5 is possible looking at the list, but, man, it'll be some damn good driving if you get into the 11's. I'd like to see you pull it off.
Old May 3, 2009 | 10:37 PM
LostAngel's Avatar
Yeah I want to get to the strip...cant wait to see. I'm sure that it's the same in the goats as it is in the vette....torque management in the tune is a real killer. I'm thinking about putting the stock tune back in, and doing a run to see if i'm right. I know during the launch, and during each shift torque management would retard the timing drastically. I know when I was stock, even with 430 horsepower to the crank...I couldn't get the back tires to spin one bit unless i popped the clutch or really 'tried'. Once I got the tune, and disabled torque management...I could be going 5mph...gas it...and hear the tires spinning through half of first gear.
I see you have around 440RWHP...what do you run in the quarter?
Old May 3, 2009 | 10:59 PM
myriadshalaks's Avatar
rot8ing
just get a better clutch, and a corvette forum. you'll be runnin 9s in no time.
Old May 3, 2009 | 11:22 PM
Detrich's Avatar
幹他媽!
shouldn't this be posted on a vette forum?
give us something that we can use... please.
Old May 3, 2009 | 11:52 PM
YaXMaNGTO's Avatar
It's a Cavalier
You're right about torque management. It's the devil, and there's more than one area in the tune that needs to be changed in order to get it all. Luckily I have a friend that helps me out with HP Tuners. Reminds me that I need to go back to him to have him look at my tune. I've got a wideband, and I'm leaning out on the spray, but running rich NA. I've thought about going from a dry shot to a 150 wet shot.
I've run 13.6 @ 107mph NA (just catback and an air filter). I haven't sprayed it at the track yet... did the dyno at one of our GTO dyno days. I was at 342 rwhp NA. Spraying it on the dyno gave me almost exactly 100rwhp. I've researched it, and a 100 dry shot on our cars is good for about 10 mph of trapspeed and about a second in the quarter, so mid 12's at 117mph. To tell you the truth, I got the 100 shot just in case I run into C6's Your car is evil fast right off the showroom floor.
But, my car is around at 500 lbs heavier than yours. GTO curbweight is 3750 and a C6 is right around 3220 to 3250, right?
Old May 4, 2009 | 07:49 AM
LostAngel's Avatar
And people wonder why I make it a rule to be leary about racing f-bodys and GTO's! Yep, you are close on the weight...i checked a couple sources and they range between 3170 and 3220....mines the base model so I don't have the extra weight of the 2LT and 3LT trims.
I wish I had your seats though...they are a thing of beauty.
Old May 4, 2009 | 07:59 AM
Transam kid 01's Avatar
The anti-ricer
This thread really makes me miss torque LOL
Those numbers look good. What tires are you using?
Old May 4, 2009 | 08:13 AM
Mawnee's Avatar
I divide by zero
Pics or it didnt happen! No really....show us some pics!
Nice car, really miss mine. It still kinda bothers me that I have to turbo my Rx8 to get to the same HP range as my vette was stock
Old May 4, 2009 | 08:19 AM
LostAngel's Avatar
Some pics:
Here is a video of it before I got the headers on:
http://www.youtube.com/watch?v=CAqxQTE_UVU
Old May 4, 2009 | 08:26 AM
Mawnee's Avatar
I divide by zero
Beautiful car
Here was mine:
Old May 4, 2009 | 08:32 AM
LostAngel's Avatar
Beautiful car
Here was mine:
Ohhh...that is my favorite color on the C5....love the stripes too.
Old May 4, 2009 | 09:06 AM
NACer4lyf's Avatar
oh yeah!
Some pics:
wow man that is a beautiful car very nice love the color
Old May 4, 2009 | 09:14 AM
wlorton's Avatar
Dr. Love
How does that bother you? The corvette has an LS-series engine.... 8 cylinders and i believe 7 liters? while the rx8 is a rotary, just two rotors and 1.3 liter..... Makes sense that the 8 cylinders would have a lil more power straight out the box....
Old May 4, 2009 | 09:35 AM
LostAngel's Avatar
I believe the C5 engines (LS1 and LS6 were a 5.7 liter.). The 2005-2007 C6 (LS2) was 6.0 liters)...the 2008+ C6 (LS3 was 6.2 liters). The C6 Z06 2006+ (LS7 with 7 liters)
Old May 4, 2009 | 12:02 PM
wlorton's Avatar
Dr. Love
Yea, I couldnt remember the 350 literage... but i remembered the ls7 427 small block is a mere 7 liters.... or litres if thats your flavor
Old May 4, 2009 | 03:01 PM
Mawnee's Avatar
I divide by zero
Oh no, you misunderstand. I dont fault the Rx8, its a great car. I'm still annoyed at the guy that demodded his 660RWHP vette and traded it in.
Old May 4, 2009 | 03:26 PM
YaXMaNGTO's Avatar
It's a Cavalier
Oooooo the color of those wheels with the red. Damn it! That's hot
theblinkof
Oct 4, 2023 05:24 PM
UnrealOne
Sep 30, 2015 11:04 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
Chapsy
Sep 22, 2015 09:57 AM
