Airbag light problem
Old May 2, 2009 | 02:46 PM
desiz's Avatar
Unhappy Airbag light problem
Ok seriously this is getting really annoying, the airbag light just never goes away. I called my local dealer and they said that the recall update for the airbag light was completed. Any way to turn get this light off?
-Thnx
Edit: I have 04 rx8 and when i turn on the car its start flashing then stays on.
Old May 2, 2009 | 02:52 PM
expo1's Avatar
He's as bad as Can
did you check the connectors under the seats? that always solves the issue for me.
Old May 2, 2009 | 03:03 PM
desiz's Avatar
no I havent,
can u explain a little bit more please.
Should I disconnect and re connect all the wires or somthin?
Old May 2, 2009 | 03:34 PM
expo1's Avatar
He's as bad as Can
Disconnect / reconnect the two harnesses that are under the seat.
Old Jun 2, 2013 | 09:30 PM
Joe4sho86's Avatar
I know this its old post but just one question have the same issue....do i disconnect and reconnect the plug with the car on....or off
Old Jun 2, 2013 | 11:57 PM
Bsburner's Avatar
lol I now have expo's car and the light is on I guess I should try un plugging and pluggin in the harness XD
Old Jun 3, 2013 | 05:29 PM
Bsburner's Avatar
Air Bag light
Originally Posted by desiz
no I havent,
Just disconnect the one on the left of the two I did that for both driver and passenger sides when the car was off and it made the light go away for now
Old Jun 3, 2013 | 09:35 PM
j9fd3s's Avatar
if you count the number of flashes, that is actually the diagnostic code, which you can look up in the FSM, which is here Foxed.ca
Old Jun 4, 2013 | 08:13 AM
Joe4sho86's Avatar
Thanks just trying to make sure if I needed the car on or off....didn't want the airbag malfunctioning or something and make it go off
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
mesaboogie
Aug 7, 2015 10:48 AM
MarkX
Jul 31, 2015 07:50 AM
