engine warranty question
Old Apr 28, 2009 | 02:53 AM
Ixonal's Avatar
so I noticed that in the powertrain warranty, if your 8 can't make it to the dealership under its own power, the tow will be covered by the dealership. I was wondering if this applied to the 8 year engine extended warranty as well. See I'm (still) looking into getting an 8, but the nearest mazda dealership is an hour away, which would be a rather expensive tow if worse comes to worse.
Old Apr 28, 2009 | 03:12 AM
cjkim's Avatar
^noob
I don't think it's covered IIRC..
i wouldnt let that worry you too much
the car doesn't have to be un-driveable to be "out of spec" for a replacement... more likely than not, if you do get a replacement, you will have symptoms weeks prior.
Old Apr 28, 2009 | 08:35 AM
Shijin-Kun's Avatar
Rotary Power!
they dont cover the towing...or at least my dealership didnt. Your engine can still be functioning and the powertrain warranty will apply as long as they find a legit reason to replace it i.e low compression.
Old Apr 28, 2009 | 08:54 AM
CTrx8's Avatar
space for rent
it is not included. the mazda roadside assistance is the same period as the bumper-to-bumper, not the extended warranty.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
BigMikeATL
May 26, 2016 12:31 AM
cschoeps
Aug 6, 2015 12:44 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
