Please someone help me out
Old Apr 27, 2009 | 10:58 PM
nezi87's Avatar
i own a 05 rx8 and im having this issue with it right now everytime i take it for a spin and if i drive it to long and come to a stop sign or red light it automatically shuts off on me ive been trying to figure out the problem i still havent i took it to mazda they said nothing was wrong has anyone else had this problem if so please let me know what it is .
Old Apr 28, 2009 | 12:14 AM
Oh man its your freaking car so just do your own freaking homework cuz its your car after all not ours so stop crying and start moving you lazy idiot.
Old Apr 28, 2009 | 12:16 AM
dozer's Avatar
on his 3rd rx8
is your throttle body getting stuck at idle?
Old Apr 28, 2009 | 12:33 AM
Brettus's Avatar
Boosted Kiwi
been serviced regularly ?
plugs
leads
Coils
Clean the maf
check the air filter
etc etc
Old Apr 28, 2009 | 12:36 AM
dozer's Avatar
on his 3rd rx8
gotta check your exhaust bearing while your at it
Old Apr 28, 2009 | 12:42 AM
Brettus's Avatar
Boosted Kiwi
/\ damn it dozer - i forgot to mention that ........ grrrrrrr !!!!!
Old Apr 28, 2009 | 12:43 AM
dozer's Avatar
on his 3rd rx8
brettus, cmon you gotta higher post count
Old Apr 28, 2009 | 12:45 AM
Brettus's Avatar
Boosted Kiwi
yeah well - I can't remember everything you know
Old Apr 28, 2009 | 12:46 AM
dozer's Avatar
on his 3rd rx8
its ok, youre so lucky im here
Old Apr 28, 2009 | 08:33 AM
Shijin-Kun's Avatar
Rotary Power!
Originally Posted by nezi87
u fukin *******
thats pretty nice thing to say...
Old Apr 28, 2009 | 08:39 AM
Flashwing's Avatar
3-wheeler
u fukin *******
Old Apr 28, 2009 | 08:56 AM
amacrx8's Avatar
What the heck..... somebody help this guy.
If it's still under warranty, I'd take it to another dealership and insist that they fix whatever's wrong.
Old Apr 28, 2009 | 11:23 AM
nezi87's Avatar
the thing is i had warranty when i took it to mazda and now i dont have it anymore i just got a 2 year bumber to bumber at the dealership i baught it from but they cant figure out the problem ive been calling and trying everything and i cannot find a person that can fix this or know at least the problem so i can try to fix it
Old Apr 28, 2009 | 02:04 PM
Davey's RX-8's Avatar
Red headed stepchild
When the car is in gear at the light, do you take your foot off of the clutch?
Old Apr 28, 2009 | 02:06 PM
nezi87's Avatar
ur kidding right? hahah its trip tronic first of all its not a stick
Old Apr 28, 2009 | 02:08 PM
Zerotide's Avatar
Snick-Snick Gearbox
Have you checked your headlight fluid recently?
JGR4444's Avatar
GR
have you recently disconnected your battery?
Old Apr 28, 2009 | 02:26 PM
nezi87's Avatar
ur a joker buddy good one u want a cookie n milk now?
Old Apr 28, 2009 | 02:31 PM
CyberPitz's Avatar
Huge hole is huge
plugs
leads
Coils
Clean the maf
etc etc
That and that?
Old Apr 28, 2009 | 02:33 PM
cornholio135's Avatar
SARX
OK I will answer ya... is it under 60k miles??? if so it is still covered under warranty. Tell the dealer to fixit.If they will not go to another dealer. Also do the basic tuneup-coils,plugs,wires. DO NOT have the dealer do the tuneup they will rape ya on parts and labor... buy the plugs from Sparkplugs.com they are about $20 each. Get the coils from finishlineperformance.com they run about $30 each. Rx8starkes.com has plug wires for $75.
hope this helps...
Old Apr 28, 2009 | 02:43 PM
nezi87's Avatar
hope this helps...
i got new spark plugs a month ago and we thought that we fixed the problem but it happend again
Old Apr 28, 2009 | 03:04 PM
CyberPitz's Avatar
Huge hole is huge
There is more to go for besides just spark plugs. We also have the wires and the coils.
ODDDOOD's Avatar
The DOOD abides.
Do you notice a lack of power above 4k rpm? Have you had any recent or past flooding incidents? Does it sound like your car is struggling to get rpms higher?
If you answered yes to any or all of these, I would recommend you ask the dealership to check the catalytic converter. If it is clogged/burnt up, then the exhaust cannot escape and choke off the engine idle. It might even throw a CEL eventually, but maybe not a big enough of an engine issue to cause that yet.
Air filter would be another good check...easy and quick. If it is clogged it could also be choking down the engine if it can't breathe.
Does your car start back up immediately after stalling?
Last I can think of is the throttle body area. I'm not sure if the rx8 has an "idle air control valve" but I have had to clean this on my gf's '98 Sentra a couple times. Her car would only stall at an idle and it was due to the IACV not fully opening when at idle and the car would die. If she would give the car some gas in Neutral the car would be fine...only on idle would it die. It would also crank right back up.
Once all the gunk was cleared out it would work for about another year until another cleaning.
Old Apr 28, 2009 | 03:12 PM
benh's Avatar
Nezi87,
This exact issue happen to me before. There is a DIY in here that you can search for. Your throttle body is dirty with carbon built up where the butterfly is. Use fine sand paper and clean it. The problem will disappear.
Old Apr 28, 2009 | 03:49 PM
nezi87's Avatar
when it shuts off ill wait like 2 minutes then it starts again ..the longer i drive my car then it happens if i got to work n bak itll be fine wich takes about 10 min if i take it out on the road for longer theres a bigger chance of it shutting down so something is over heating and shutting my car down
