Minimum Rotor Thickness?
Old Apr 24, 2009 | 06:01 PM
TX Minimum Rotor Thickness?
Does anyone know what the specs are? It should be on the rotors right? Any input on getting them turned?
Old Apr 24, 2009 | 06:14 PM
I'm not going to look it up.
rotors can not be turned.
Most rotors nowadays can not be turned.
they don't make them thick enough anymore.
Need to reduce weight and save on gas.
Old Apr 24, 2009 | 06:18 PM
Thanks for the input.
Old Apr 24, 2009 | 07:10 PM
invasion08's Avatar
What rotors are you using OEM or Aftermarket? Why do you think you need your rotors turned?
Old Apr 24, 2009 | 09:30 PM
rx8cited's Avatar
Senior Member
Originally Posted by 9krpmrx8
Does anyone know what the specs are? ...
Rotor width spec (minimum): 22m front/ 16mm rear
Old Apr 24, 2009 | 09:56 PM
TX
Thank you!!!
I need this because I bought used rotors with 6k on them and mine have 92k on them. I just wanna get the ones I bought cleaned up in case there is any build up (read break FAQ). I was gonna buy aftermarket but I just got a new clutch and I need to do my breaks front and back and I'm buying wheels so aftermarket rotors will have to wait.
Old Apr 26, 2009 | 06:46 PM
justjim's Avatar
justjim
Thank you!!!
Just clean them with spray brake cleaner when you put them on and then go out and bed in the brake pads as per the Brake FAQ. That should be all that is necessary even if there were uneven pad deposits which there likely are not.
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
patriotjj
Sep 13, 2015 08:09 AM
