PatN217
04-18-2009, 11:19 AM
This past weekend I replaced the stock clutch with a stage 1 kit from exedy. Everything went fine as far as the clutch swap. The instant I started driving the engine couldn't seem to find the correct idle. It would also stall periodically while trying to find the idle speed. On top of that, when I am traveling at a constant speed the engine jerks the car. There is no change in RPM but you can feel the differences in power. Taking it to the dealer is a last resort. I've checked the neutral switch and everything seems to be in good order. The ECU hasn't thrown a code yet either. After resetting the KAM there is still no difference. The only thing I can think of at this point is a problem with one of the spark plugs and possible misfire. Anyone have this issue after replacing a clutch or just in general?
dannobre
04-18-2009, 12:39 PM
Idle switch on tranny ...did you hook it back up? If you did, check the wiring cause it's not working properly
Jon316G
04-18-2009, 01:59 PM
+1
When I did my clutch swap I noticed the four wire harnesses on top of the tranny.
Two of them were white and the other two were black.
Not wanting to mix them up (the two whites or the two blacks), I put a thick sharpie line on the sides of one white harness and one black harness (the black sharpie was still visible on the black harness).
That way, I could tell the two white and two black harnesses apart.
Is it possible that you got the two harnesses mixed?
Did you have it labeled in any way?
PatN217
04-18-2009, 02:15 PM
They were both hooked up correctly. I did the same marking trick with the sharpie not wanting to get the connections mixed up.
PatN217
04-18-2009, 04:17 PM
Just got it back from the dealer. Diagnosis - engine was misfiring because ignition coils had gone bad. Certainly wasn't expecting that considering a had all new coils, wires, plugs, and engine put in this past December. I guess Mazda just makes crappy coils. Hopefully mine will keep going bad within the parts warranty so ill never have to pay for them.
teknics
04-19-2009, 01:11 AM
+1
believe it or not, it doesn't really matter. it didn't matter on old ones either. either that or i get lucky every time. just a one wire split with a switch, no matter which way you connect there's pcm signal on one side ground on other, press switch PCM sees ground :).
kevin.
Jon316G
04-19-2009, 01:32 AM
I thought that but wasn't completely sure at the time.
Better to play it safe ;)
But its good to know for future reference... thanks!
