The Yes It Did Fit Thread
Old Apr 18, 2009 | 10:01 AM
bee_afraid's Avatar
What I'm doing:
I've decided that the best way to catalog different wheel/tire fitments on the Rx8 was to make a master-list of everyone's setup and previous setups. After a large group of people have posted there setups then I will make a new thread for the master-list.
Why I'm doing it:
To provide the guys who routinely help out in The Will It Fit Thread a break by preventing the same questions from being asked over and over again and to make the information more easily attained for information seekers.
Post should include:
Wheel size and offset
Tire brand and size
Suspension info
If a spacer was used and if so what size
stock, rolled, pulled, or trimmed
Problems or not
Please copy and paste in your post:
Rims:
Tires:
Suspension:
Spacers:
Fender-wells:
Problems:
If you're not certain on your setup then please don't post in this thread. If you have questions about a setup please go to https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/will-fit-thread-133500/
Yes I know that all of this information is available in The Will It Fit Thread but it is 87 pages long and I don't have the time nor the energy to accumulate the information.
Please participate and help out,
Daniel
Old Apr 18, 2009 | 10:03 AM
bee_afraid's Avatar
I'll start:
Rims: 17x9 +45
Tires: Falken Azenis RT-615 255-40-17
Suspension: Tokico D-spec shocks/springs 1.25/1.25 drop
Spacers: None
Fenderwells: stock
Problems: None
Old Apr 18, 2009 | 03:19 PM
Big Money Pit's Avatar
Rims: 5zigen FN01r-c 17x10 +25
Tires: Falken Azenis 245/45/17
Suspension: Swift Springs
Spacers: none
Fender-wells: torn to pieces?
Problems: Rubs. A lot. Can't get away without a roll, here. If you try to, it'll rub so much that the rear tires will eventually pull the inner lip DOWN with them, instead of up. Once you get a roll, it's alright. Rubs occasionally. If you get the wheels and tires without stiffer suspension your fronts will rub so much that they'll actually slow you down during cornering. It'll also look like a monster truck without it lowered.
Old Apr 18, 2009 | 04:27 PM
jones75254's Avatar
17x9 +35 5zigen FNO1R-C all 4 corners
Bridgestone Potenza RE-O1R 245/45/17 all 4 corners
Tein S springs
Tokico D specs
-1.7 Front camber, -1.3 Rear Camber
No spacers, no fender modification and no problems
Old Apr 18, 2009 | 08:59 PM
Rims: 19x9 +40
Tires: Re01 235/35/19
Suspension: S-Techs
Spacers: none
Fender-wells: stock
Problems: none
Old Apr 18, 2009 | 10:12 PM
Rims: SSR Comp 18X10.5 +43
Enkei RPF1 18X9.5 +45
Tires: Advan Neova 265-35-18
Nitto NT01 275-35-18
Suspension: KW V3 at about 25.75" ride height
Spacers: Never
Fender-wells: Stock
Problems: None
running about -2.0 camber in the rear and -2.6 Front
Tons of room on the inner front, about 10 mm from tire to fender liner at lock...inner rear has about 10mm to body mount of strut
Old Apr 19, 2009 | 12:12 AM
dmak_el's Avatar
Rims: 18x8.5 Gramlights 57F +45
Tires: RE01R 235/40/18
Suspension: MS sport springs and shocks
Spacers: none
Fender-wells: stock
Problems: none
I am thinking of adding 15mm spacers on all corners. From the research i did, it will just fit without rolling fenders, but very tight. I will find out when i have money for the spacer.
Old Apr 19, 2009 | 04:10 PM
Fortunate Few's Avatar
Irollerblade.
Rims: rota grids 18x9.5 38 offset
Tires: federal 265/35/18 in the back 255/35/18 up front
Suspension: stock
Spacers: none yet
Fender-wells: stock?
Problems: the back center caps wont go on because that bolt thing in the center extends out too far which is why i might consider thin spacers.
Old Apr 19, 2009 | 04:33 PM
cjkim's Avatar
^noob
Rims: 18x8.5 +38 5zigen ProRacer GN+
Tires: RE960AS Pole Position 225/45/18
Suspension: espelir GT / Tokico D-specs
Spacers: none
Fender-wells: stock
Problems: none
Ride height:
13.25 all around
might i suggest adding ride height (measured from center of wheel to the fender)?
Old Apr 19, 2009 | 09:52 PM
T-ReX-8's Avatar
Stormtrooper RX8??
I have the most experience with the 17X10 +25 fitment issues so I'll indulge:
Rims: 5zigen Timeattack/Redline FN01r-C 17x10 +25
Tires: Nitto NT-01 245/45/17 and Nitto NT-05 255/40/17
Suspension: HKS Hipermax II Coil Overs
Spacers: LOL!
Fender-wells: Must be modified
Pre. reqs.: This setup REQUIRES coil overs. Do yourself a favor and don't cheap out on them and use springs, you will rub A LOT regardless of what you do.. The only other option is racing springs, and I'm not talking lowering "racing" springs, I am talking custom ordered high spring rated springs on a modified aftermarket strut. Also the stiffer you make the car, i.e. strut bars, sway bars, roll bars, under braces, the better.
Problems: Even at stock height it rubs... Bad. Lowering not possible without fender modification. When lowered at the degree mine is (pretty much "slammed") you need to do a few more modifications beyond rolling.
Solution: Fenders MUST be rolled. This isn't even an option at stock height. The fronts don't have much of an issue until you slam the car at which point the side marker light mounting area digs into the tire. this must be shaved and new methods used to attach the side marker or grind the area including the screw back as much as possible. When turning th wheel comes in contact with the fender liner vents, it wont harm the tire (even the soft R compound tires I run) just let it rub itself a path. The rears are another issue. It will take some aggressive camber to get the wheels to fit even with the lip being rolled. Along with that the fender liner in the back half must be cut because of the angle it is molded into it is quite rigid and will rib back against the tire and bind so cut it till it is flat like the rest of the liner. If dumped the car will rub the UHMW bumper mounting pieces, this also must be shaved down to allow the tire to clear. The the piece will do no damage (other than rub/heat marks on the upper sidewall) to the tire due to how soft it is but it will constantly rub the tire and that is no bueno..
Conclusion: This setup will fill your wheel well better than nay other setup we have available without pulling your fenders. (ugly) But the lower you want to go, the more work that needs to be done to allow them to function properly. The work needed is well worth the benefits.
Old Apr 19, 2009 | 10:05 PM
Camel8's Avatar
Camel Lover Extrodinaire!
Rims: Tenzo Cuzco - 19 x 9.5 + 45 all round
Tires: Vredestein Ultrac Sessanta 245/35/19 all round
Suspension: Bilstein PSS9 coilovers on rediculously low, not sure on drop but at lowest recommended
Spacers: I NEED 15mm spacers on the back and 10mm on front
Fender-wells: Rolled but didnt need it
Problems: None, zero, in fact i wish they made the wheel in a +35 offset but the only one with a 35 offset is the 5x120....
Old Apr 20, 2009 | 03:10 AM
my mini van..
yes it fit no modification at all =)
Old Apr 20, 2009 | 05:54 AM
foo77's Avatar
4th batch : Apr 03'
^ thats really fit this thread, good one lol anyway here's mine
Rims: Tenzo R DC-5 ver. II , 19x8.5 +45 all around
Tires: BF Goodrich G-Force Pro 235-35-19 all around
Suspension: Tein Type Flex
Spacers: None
Fenderwells: stock
Problems: None
Old Apr 20, 2009 | 12:53 PM
Fate710's Avatar
Super Low & Super Slow
Rims: 18x10 +48 KMC GTXs
Tires: 245/40/18s
Suspension: Stock but have Sprint 2" Springs on the way
Spacers: Will fit without spacers, but its extremely close in the rear. I'm running 5mm spacers and will probably end up putting 10mm spacers on it
Fender-wells: No mods as of yet
Problems: NONE
Old Apr 20, 2009 | 03:06 PM
RawrX8's Avatar
Grocery Getter
Rims: Enkei RPF1 18x9.5 +45 offset all around
Tires: Goodyear Eagle F1 All season 275/35/18 all around
Suspension: Tein S Tech springs
Spacers: None
Fender-wells: None
Problems: None. Bumped the rear fender once. I had a passenger while jamming on the freeway and hit a mild bump/pothole.
Old Apr 20, 2009 | 03:13 PM
dozer's Avatar
on his 3rd rx8
rims - p45fs 18x8.5 +30s in front and +25s in back
tires- dunlop 5000m 245/40s all around
suspension - dropped on RSR springs
spacers- none
fenderwell- not rolled
problems- none
looks- flush with the body, thank god for the camber in the back or i mightve had to roll my back fenders, clearance is less than a quarter inch
Atilla's Avatar
I am THAT guy
Rims: Sportmax XXR 009's 18x8.5 +35
Tires: 245/40/18 BF Goodrich KDW Ver. 2's
Suspension: Swift Mach Springs - OEM shocks
Spacers: None
Fender-wells: No Rolling
Problems: None
Camber: Slight camber -.5
Pic:
EXCELLENT THREAD.
Request for sticky??
Old Apr 20, 2009 | 03:16 PM
dozer's Avatar
on his 3rd rx8
^good call atilla
Old Apr 20, 2009 | 03:33 PM
bee_afraid's Avatar
Any information that people don't feel bothered by posting is appreciated. I just figured that the large majority of people wouldn't know their ride height right off hand.
I'm thinking about making the master list into 3 categories.
No modifications required
Rolling required
extensive fitting required
Then under each category I will list everyone's setups by rim size.
Thanks for everyone's help and please keep the info coming. Idea's are very welcomed.
Old Apr 21, 2009 | 07:39 PM
DOMINION's Avatar
I don't buy Kool-Aid
Rims: XXR (Sport Max) 18x8.5 & 18x9.5 32 off set
Tires: Stockers 225/45/18
Suspension: Tanabe Springs GF210
Spacers: No
Fender-wells: Not Rolled
Problems: No
Old Apr 21, 2009 | 09:49 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
If your wheels came with the standard Rota cap that happens. The tall set of caps worked on my car with the Rota P45.
Old Apr 21, 2009 | 09:54 PM
dozer's Avatar
on his 3rd rx8
^i need some of those
Old Apr 21, 2009 | 10:31 PM
DOMINION's Avatar
^You got some sick wheels man
Old Apr 21, 2009 | 10:32 PM
dozer's Avatar
on his 3rd rx8
me?
Old Apr 22, 2009 | 02:57 PM
Originally Posted by dozer
me?
No, XDEEDUBBX
