Using low impedance injectors.
Old Apr 11, 2009 | 04:51 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Question #1: Can the stock 6 port PCM handle driving one set of low impedance injectors in the secondary position?
Question #1a: If not, what physical alterations (resistor pack?) could be done to allow the stock computer to do it?
Question #1b: If it can, what allows it to do so?
Question #2: WHat allows the microtech system to run low impedance injectors?
I should note that I have been mistakenly running low impedance injectors in the secondary position for a few weeks and several hundred miles.
Old Apr 11, 2009 | 06:00 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
#1 - No. You could burn up the PCM.
#2 - Int-X has injector drivers that can handle low, high, or a combination of the two
Old Apr 11, 2009 | 07:59 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
So are you saying that based on an understanding of the setup of the computer or from extrapolation from other systems? Also, based on extrapolation, is there not some threashold of resistance in total from all the injectors that will be sufficient to allow some low impedance injectors to be used?
I only ask because fixing this will require a significant investment and downtime.
Old Apr 12, 2009 | 08:14 AM
tdiddy's Avatar
I am saying this based on a discussion I had while sitting in my garage with MazdaManiac and Charles R. Hill testing 7 different sets of injectors. Then based on emails and a phone conversation I had with Scott Glassburn about how the int X handles injectors.
If you are going to run the OEM computer for your EMS then you should be running high impendance injectors in all the banks.
Old Apr 12, 2009 | 12:34 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Thanks. Also double thanks for the primary idea. Going to go down and try it out in a bit.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Michael Bryant
Oct 12, 2015 03:07 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
xAgyex
Sep 28, 2015 08:54 AM
