View Full Version : IDENTIFY THESE INJECTORS AND WiN...
carbonRX8
04-11-2009, 03:25 PM
A BRAND NeW...
Well, I dont have anything to give away, but you will have my eternal gratitude.
The injectors on top are stock bank 2
The injectors on the bottom are my new bank 2. The fat ones are Rochester 780cc/min 17113742. I need to know the skinny black ones to find their latencies. They had hand written scribble on them, but I did not record it. No other identifying casting marks. These were purchased from Mazsport early '08.
I should have used a camera with my macro lens, but it is too late now.
http://www.rx8club.com/attachment.php?attachmentid=136768&d=1239481520
dannobre
04-11-2009, 03:40 PM
Siemens I think.... 60#/hr long Machined to fit :)
carbonRX8
04-11-2009, 04:19 PM
Crap. I just realized I have a major problem with the injectors I have. The big fat injectors are low impedance. The stocks are high as well as the Siemans injectors.
Thanks for the info dan.
This might have been fine on the Int-x (might have a resistor or some good heat sink) and is likely a very good idea for response, but I dont know if the stock pcm (with an accessport) can stand to have a secondary running low resistance.
Any opinion on this would be grand.
{off to do some searching}
dannobre
04-11-2009, 05:25 PM
They could easily be high impedance RC has a 785cc HI set that look identical as well....I have a set siting on my workbench..I can check them for you on Monday when I get back from LA. AFAIK they are all high impedance
carbonRX8
04-11-2009, 08:05 PM
Are you talking about the thicker set in the pix? Those unfortunately are almost certainly low impedance. They have a number cast on them that IDs them as rochester low impedance injectors. Looks like I need to get another set of injectors.
I am thinking a matched set of four 650cc HIs from RC, but I am looking around. If you know of a good source for injectors and grommets, let me know.
Not looking forward to ripping off the UIM again.
dannobre
04-11-2009, 11:27 PM
I have a set of 4 550 Denso's in mine right now......and the Seimens 650's
carbonRX8
04-12-2009, 07:53 AM
Are the seimens in or out of your car? They for sale?
tdiddy
04-12-2009, 08:21 AM
Why not just run 1 set of yellows for the primaries (380), run 1 set of yellows for the secondaries (380), then the skinny black (seimens 650's) for the primary 2s? This would be enough fuel 400 crank hp.
arghx7
04-12-2009, 09:03 AM
get an ohmmeter across the terminals. 2-3 ohms is low impedence, over 10 ohms is high impedence
dannobre
04-12-2009, 10:33 AM
IN.....Sorry :( Running them as Primaries :)
carbonRX8
04-12-2009, 12:32 PM
This is a good idea. This is why I come to this crazy forum.
I was keeping the reds in primary for idle and cruise. But 290 to 380 should not be that big of a decrease in granularity. Might try this out.
carbonRX8
04-12-2009, 04:12 PM
Siemens I think.... 60#/hr long Machined to fit :)When you say "machined to fit" you mean they were modified? If I get another two from somewhere else, are they not going to fit?
