NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Can someone PLEASE help me install this Saterday or tonight. PLease HELP...
Old Apr 10, 2009 | 01:16 PM
NYC Drift King's Avatar
Supercharged by Pettit
Old Apr 10, 2009 | 01:59 PM
In the tri state area.
Old Apr 10, 2009 | 02:13 PM
Kel Rx8's Avatar
if your not 1st your last
umm what are you installing would be good
and I am working on my s2k again tomorrow
cel o2 sensor and damn door speaker keeps getting loose
Old Apr 10, 2009 | 02:19 PM
from the picture it seems as though you're installing:
- RB gauge pod
- 3 gauges in pod
- Oil adapter with sending units
- Coolant adapter with sending unit
- Vent Pod Gaguge
- Additional gauge
This is probably better done tomorrow since it's not exactly a quick job. Good luck, hopefully someone in your area can help. If you need help with grounding / running some of those wires check out my sticky thread
Old Apr 10, 2009 | 03:40 PM
^Thanks jedi....
The gauges are:
oil temp
oil pressure
water temp
volt
I have a boost for when i go turbo, but i want to install these for now before DGRR.
If I had a shop do how much do you guys think they would charge???
Old Apr 10, 2009 | 03:43 PM
def we could do it together, but hopefully some one can come by to help with the gauges. This will be a 1st for me. I could return the favor, I have a uncle with a body shop, and i can do general mechanic work...
Old Apr 10, 2009 | 06:13 PM
chrism's Avatar
Misfit Moderator TnC
omar i can help you saturday night or wednesday night.....saturday i gotta do laundry and go food shopping after that im good
Old Apr 10, 2009 | 09:28 PM
I spoke to u on the phone chris so u know the deal...
Old Apr 10, 2009 | 10:39 PM
chrism's Avatar
yeah we set.....ill call you tomorrow afternoon
Old Apr 11, 2009 | 01:41 AM
LiL BenNy's Avatar
Bubblicious? DEF.
id help but i have my own headaches to sort out before deals.. goodluck
Old Apr 11, 2009 | 06:38 AM
chrism's Avatar
your welcome to come up benny.....
Old Apr 11, 2009 | 09:08 AM
LiL BenNy's Avatar
Bubblicious? DEF.
lol re-read my prevous post but thanks for the offer
Old Apr 11, 2009 | 09:58 AM
Sarcazum!!!!!!!!!!!!
lmao
Benny will come to u at 3am lol jk
Old Apr 11, 2009 | 12:32 PM
chrism's Avatar
you know my garage is open!
Old Apr 11, 2009 | 01:50 PM
jskup1's Avatar
The Chief
You're probably going to have to remove the oil temp sensor from the fitting until after you tighten the filter bolt on. It won't turn with the temp sensor installed. At least it didn't on mine.
Old Apr 11, 2009 | 04:13 PM
NoOdLe BoY's Avatar
id help if i knew how lol. but im not up to that yet on my car. hope everything goes smoothly.
Old Apr 11, 2009 | 09:43 PM
chrism's Avatar
i got them all in and on but it looks like 2 of the guages are malfunctioning....oil pressure is working and volts....but water temp, and oil temp crapped out.....
Old Apr 12, 2009 | 08:10 AM
Andrew R's Avatar
TN motherfuckin' C
I'll be at my garage for a bit today if you wanna have meet look at them. I don't have a ton of free time -but I'll see what I can do.
Just hit me up Omar, I headed there in about 30min.
Old Apr 12, 2009 | 08:30 AM
chrism's Avatar
omar is on his way to south carolina.....he wont be back till tuesday.....getting his car registered and licence
Old Apr 12, 2009 | 10:57 AM
Andrew R's Avatar
TN motherfuckin' C
ahhhh h OK
Old Apr 12, 2009 | 12:08 PM
CoNsRx7's Avatar
T n C mEmBeR
[QUOTE=NYC Drift King;2961898]Can someone PLEASE help me install this Saterday or tonight. PLease HELP...
saterday??? or is it saturday...
Old Apr 12, 2009 | 03:21 PM
I'm in SC right now.
Old Apr 12, 2009 | 06:28 PM
chrism's Avatar
get the car handled and get back!
Old Apr 13, 2009 | 02:03 AM
chris: what were the gauges doing?
where were they grounded?
Could it be a bad sending unit?
Old Apr 13, 2009 | 05:47 AM
chrism's Avatar
the guages all shared ground and power so they all powered up just fine.....the oil temp and water temp didnt work but the oil pressure did.....the senders looked fine and i tested them by grounding each individually and nothing so it wasnt the sender being wrapped in too much teflon......all the wires were brand new.....only assumption left was bad guage or bad sender....either way he needs 2 new guages
