starting issues
Old Apr 6, 2009 | 04:14 PM
sinneRX8's Avatar
starting issues
I ve read all the threads that have anything to do with starting. I dont think any of them apply to me, but maybe Im just not understanding. I recently baught my 8 from a dealer. I have an issue now. Which just started today. I coudlnt make my car start. at first the engine wouldnt crank over. then after 4 -5 attempts. it cranked and started but very slowly. I am still ahving these issues. figuered it might be my battery, but battery is strong. possibly the starter? who can help?
Old Apr 6, 2009 | 04:21 PM
invasion08's Avatar
More info about the car. Year, Mileage, A/T or M/T, and any other history you might know. Mazda did come out with an updated starter. Find out when the last time the coils and spark plugs were changed or even replaced at all.
RX-8 Bulletins
http://www.finishlineperformance.com....php?pageid=11
Old Apr 6, 2009 | 07:22 PM
Jon316G's Avatar
Grasshopper
If you have an earlier year ('04 or '05) then it could be the starter.
They are known to be weak and have since released an upgraded unit.
If you are able to drive the car at high RPMs without constant misfires, then I doubt its an ignition problem (coils, spark plugs, plug wires).
Old Apr 7, 2009 | 09:03 AM
EDZRIDE's Avatar
2005 White GT
First things first! Load test the battery and check the charging system.
Old Apr 11, 2009 | 10:38 PM
rotarydrifter's Avatar
same problem here 2004 mt 41,xxx miles im thinking its that faulty starter every with the 04 models' have had replaced... this morning i was gonna change my belts on my new fc i just bought
but i needed to move my rx8 out of the driveway.... and nothing!!! i cranked it and began to think it was the battery, so i jumped it, cranked it again and nothing so i stopped didnt want to flood it so i had it towed to the nearest dealership... changed spark plugs no more than 8k ago,msd wires...
help
Old Apr 12, 2009 | 11:36 AM
RC1998's Avatar
I have a 2005 and the same problem. Started my car yesterday, backed it out of the driveway and shut it off. Started it 15 minutes later and drove it back in.
This morning it won't start. Seems to be cranking okay but won't turn over. I tried holding the gas all the way down and cranking. Tried to boost it just in case but still won't start. Battery sounds fine.
Any ideas?
Old Apr 12, 2009 | 11:38 AM
Jon316G's Avatar
Grasshopper
Sounds like a flood.
Old Apr 12, 2009 | 08:55 PM
RC1998's Avatar
[QUOTE=rotarydrifter;2963822]same problem here 2004 mt 41,xxx miles im thinking its that faulty starter every with the 04 models' have had replaced... this morning i was gonna change my belts on my new fc i just bought
help [/QUO
Just wondering how things went at the dealer. Was it solved quickly?
Old Apr 13, 2009 | 11:38 PM
yeah i have an extended warranty and it was covered!!! 1212 or 100,000 mi. they fixed it the next business day( took it in Saturday, was solved on Monday morning!!) new spark plugs and there gonna fix the passenger female buckle! and i got a free rental!!! for the most part, they come through.
i cant complain new plugs!
Old Apr 15, 2009 | 08:43 PM
however when i turn it on and it seems to hesitate to start up, it'll crank over for a bit longer than usual then fire up is this normal? any maintenance tips? or suggestions?
Old Apr 15, 2009 | 08:46 PM
Jon316G's Avatar
Grasshopper
Hesitating startups could be the starter (which is common with the '04s) or a weak batter.
ouimetnick
25
Sep 14, 2023 01:44 PM
05TR1CH
Apr 18, 2023 04:56 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
SUKIEE
Oct 9, 2017 09:41 PM
