Larger tires = Throwing off speedo?
Well the time has come that i replace the current stock tires on my 9" wide aftermarket rims with proper sized ones which means i will most likely be getting some 265/35's or 275/35's. My question is how much can i expect these tires to throw off my speedometer by?
Thanks in advanced
Thanks in advanced
http://www.miata.net/garage/tirecalc.html
275 would be closer
275 would be closer
the correct od of the stock tire is 25.9 "
go from that.. width sidwall and rim diameter have nothing to do with it.
you just have to look at the outside diameter of the tire at 25.9" and you are fine.
http://wheelsmaster.com/rt_specs.jsp
Give this a bash, slightly different than the miata one (gives offset calc etc...)
ok so if the stock setup is 25.9 and the calculator shows me at 25.6 with the 275/35 combo will that be a difference of like 1/2 a mph? or will it not even be noticeable.
O and by the way i feel like a idiot because i was using the search button and reading through threads and couldnt find anything but now that i type in "tire size calculator" i find a ridiculous amount lol
this is from real world experience and gps..
Ok thanks for the help. So at lower speeds will it be off more? Or is 4 mph about the highest its going to be off? And is it possible to get the speedo corrected through a justifiable way without spending a substantial amount of money to do so?
JimmyBlack
273
Feb 10, 2020 10:23 PM
drlubell
Sep 26, 2015 11:58 PM
