FI Air Flow: Compare & Discuss
Old Mar 31, 2009 | 12:17 PM
Derex'8's Avatar
ReDuX
Well this is by no means to be taken as "Hard" or "exact" data. As there are to many variables @ play.
I just want to spark a discussion here, for data comparison that can give us "ballpark" figures and maybe even help diagnose problems
So on with it.
I would like for every1 to post up the following from there FI setup:
Mine
G/sec: 322.91
PSI: 12.2
Ambient temp: 54F
lbs/min: 42.59
Turbo: Garret T4 60-1
Did a wot run & @ 12.2 psi I'm seeing around 322.91 g/sec. (Ambient temp was 53F) Which if my math is right converts to about 42.59 lbs/min.
What are you all seeing?
Just to help
1 gram = 0.00220462262 lbs
Then take that number & * by 60
Old Mar 31, 2009 | 03:01 PM
arghx7's Avatar
^ what does your car dyno? I have heard that a rotary is something like 7.5-8.0whp per lb/min , while a piston engine is closer to 10whp per lb/min. So that would put you in the 320-340whp range by that rule.
Attached Thumbnails FI Air Flow: Compare & Discuss-60-1_plot.jpg
Old Mar 31, 2009 | 03:26 PM
MazdaManiac's Avatar
422 g/sec
13 PSI
65*F ambient
~56 lb/min
Garrett GT3076rWG (custom)
Old Mar 31, 2009 | 03:34 PM
arghx7's Avatar
hypothetically, if a motor were to injest 42.59 lb/min @ 12.2psi, as Derex'8 did, you would be somewhere in the 68% efficiency range of the GT3071.
12.2psi boost:
12.2/14.5 = ~.84 bar above atmosphere, so the pressure ratio is around 1.84, which I approximated the best I could here.
Attached Thumbnails FI Air Flow: Compare & Discuss-gt30_efficiency_rx8.jpg
Old Mar 31, 2009 | 06:57 PM
Derex'8's Avatar
ReDuX
Well I know what my next purchase will be, a Ball Bearing 60-1 CHRA for my turbo. Damn Jeff that is some very impressive #'s you have there. That GT3076rWG is no joke.
What was your actual post compressor temps?
Mine was steady @ 97*F
Old Mar 31, 2009 | 06:59 PM
Derex'8's Avatar
ReDuX
arghx7 I have yet to get it dyno'd
Old Mar 31, 2009 | 07:10 PM
Brettus's Avatar
Boosted Kiwi
Maf calibration has a huge impact on this so if that is not spot on your number is just a number .
Also you need to measure boost at the turbo - not the UIM to see where you are on the chart ....
I was on stock calibration when I saw 330 g/s but i think in reality I'm around 305-310 g/s
33o g/s (because thats what i saw & it sounds better )
8 psi boost at UIM (12.5 psi at turbo) in 6800-8000rpm range
16 deg Celcius
Greddy / cold side upgrade
Old Mar 31, 2009 | 07:28 PM
Derex'8's Avatar
ReDuX
Yeah because something is definately up with mine after seeing you all's #s. I'm starting to wonder if the turbo I have is truly a 60-1 as I had bought it second hand remanufactured.
The comp housing says .60
I thought 60-1 came in a .68 or .70 comp housing
What all do I need to measure to confirm if my turbo is a 60-1.
I do know my maf cal is way off @ the moment. Fuel trims are pegged @ 25% @ idle.
Old Mar 31, 2009 | 07:39 PM
05rex8's Avatar
sold the 8... :(
348 g/sec
5psi
50 degrees F
46.03 lb/min
Fluid Motorsports GReddy upgrade 28G
Old Mar 31, 2009 | 08:14 PM
chickenwafer's Avatar
Nope
GT3071R
380g/s is what I usually see at 9psi around 7500rpm
So 50.3 lbs/min of air.
High boost run:
11.8psi
405 g/s
53.6 lbs/min
Felt like the car was skipping across the ground!
There is also a great conversion website located HERE that converts all kinds of flow measurements. Great for helping to figure out injector sizing, I found.
Old Apr 1, 2009 | 09:08 AM
arghx7's Avatar
a true 60-1 wheel has 7 compressor blades with a 3" diameter (measured if you pull off the compressor housing). I had one. does yours have 7 blades? if it has 6, it is a T04E variant. they are commonly mislabeled/misunderstood. The 60-1 does NOT have to come with a .70 A/R compressor housing. it comes in a bunch of different housings.
Attached Thumbnails FI Air Flow: Compare & Discuss-turbokit2.jpg
Old Apr 1, 2009 | 02:10 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by 05rex8
348 g/sec
5psi
50 degrees F
46.03 lb/min
that's a lot of air at only 5psi - your maf must be well off calibration .
I'm heading to dyno very soon and am planning to be logging airflow while on the dyno so that may be interesting .
Old Apr 1, 2009 | 05:46 PM
05rex8's Avatar
sold the 8... :(
or my upgrade just pwns yours
Old Apr 1, 2009 | 06:22 PM
Brettus's Avatar
Boosted Kiwi
meet me at the x roads at sundown ..... bitch
Old Apr 1, 2009 | 06:44 PM
05rex8's Avatar
sold the 8... :(
rofl!
Old Apr 2, 2009 | 02:08 AM
Brettus's Avatar
Boosted Kiwi
did i see in another thread that you can run 10psi all the way to 9000 rpm ?
How did you do that - do you have the stock Greddy wastegate setup ?
Old Apr 2, 2009 | 02:13 AM
Kane's Avatar
Senior Member
I think the WG is ported on the Fluid and the BNR; maybe they have upgraded actuators too?
Old Apr 2, 2009 | 04:31 PM
Nope
Or maybe it's a turbo handcrafted by God
Old Apr 3, 2009 | 06:23 PM
05rex8's Avatar
sold the 8... :(
my bad, I should have been more clear on that
I'm not sure what thread you are referring to, but if it's the coils one I meant I have my boost set to 10 psi and can run to redline without any misfires with oem coils, not that my boost stays solid all the way to redline
but yes my wastgate is ported and my boost controller can mess with the spring setting
and Dave might be onto something here....turbo handcrafted by God...yes.......that's it. end of story. no more comments. thank you.
Old Apr 3, 2009 | 06:27 PM
Brettus's Avatar
Boosted Kiwi
you had better get that bad boy dynoed before I beat you to it .....
IE >300 whp on a Greddy
Old Apr 3, 2009 | 06:29 PM
05rex8's Avatar
sold the 8... :(
lol..I need to upgrade my injectors before I dyno...so you might beat me to it anyway. I don't plan on staying at 10 psi until I do upgrade them.
Old Apr 6, 2009 | 05:41 PM
05rex8's Avatar
sold the 8... :(
Ok new numbers
374 g/sec
8psi
45F
49.47 lb/min
Old Apr 6, 2009 | 09:50 PM
Kane's Avatar
Senior Member
Today - 388 g/sec at 10 PSI and 6400 RPM
Ambient 80F - Hawaii
GT3071R
Old Jun 29, 2009 | 11:18 PM
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Today-
353 g/s
7 psi
64 degrees
BNR Turbo
Old Jun 29, 2009 | 11:35 PM
Brettus's Avatar
Boosted Kiwi
nice bump . I forgot about this thread .
FWIW I tried to get maf figures at the same time as i dynoed last . Unfortunately I discovered that when you hit the rev limiter (like when you dyno) it messes up the dudelogger and I didn't get the readings I wanted .
However later logs I did very strongly support the theory that peak wheel hp and peak maf numbers are very closely related .
Of course this only applies if your maf is properly calibrated IE target vs actual lambda is equal and LTFT = 0
JCAB - when are you off to the dyno ?
