New to the RX, Potential Engine Problem?!
Old Mar 25, 2009 | 08:43 PM
m1943's Avatar
Hi guys, got an RX with 17,000 miles last fall, didn't drive it that much, saw a white-ish foam-type substance on the upper part of the dipstick right after the oil change. The oil I put in was Castrol Fully Synthetic, European formula, 5W30. No smell, noise, or power loss though. Changed that oil, put Castrol in again, and saw the same white foam-type thing on the dip stick. It's not coolant I don't think. Doesn't seem like water to me, either. What could it be and do I have an engine problem??? Thanks for any feedback.
Old Mar 25, 2009 | 08:48 PM
greg985's Avatar
The 337
ohhh noeeesssss!!!!
Old Mar 25, 2009 | 08:50 PM
jsjjr's Avatar
His 8
You might want to try this thread.
https://www.rx8club.com/showthread.p...ght=white+foam
Old Mar 25, 2009 | 08:59 PM
shazy's Avatar
Ugh, someone lock it before he gets flamed. I swear, I think there is more than 1000000-124879y6234798236497834687936 threads on this. Yay for +1 post count.
Marklar's Avatar
It is, it's just condensation. It's normal, nothing to worry about.
Old Mar 25, 2009 | 10:43 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
RX-8s also make cappuccinos.
Old Mar 28, 2009 | 05:22 AM
m1943's Avatar
OK, I'm convinced now that it's normal for this particular car (not specifically MY car, but RX8 in general). Not any other car, but this one. Then again, how many other cars are there with a rotary engine in them? I certainly is a fun car to drive, noisy and kinda sluggish in 1st gear, but fun.
Old Mar 28, 2009 | 08:13 AM
j67345's Avatar
Glad everyone could help convince you...there's a TSB for this as well
Old Mar 28, 2009 | 08:29 AM
TitaniumRotor04's Avatar
All-Rotor
I am sure it will be fine but I use 5W-20 oil only not part synthetic, full synthetic or European formula if you just use regular oil what Mazda recommends then you should be fine. As for the white foam-type stuff not sure but I had that before myself not a big deal could be condensation. Good Luck.
Old Mar 28, 2009 | 08:45 AM
I8U's Avatar
I8U
^I love guys like this.
Old Mar 28, 2009 | 09:19 AM
jones75254's Avatar
LOL
Old Mar 28, 2009 | 02:37 PM
tsxmidship's Avatar
its not condensation its your engine!!@!$%! btw the exhaust system expels cats that go meowwwwwww
Old Mar 28, 2009 | 02:59 PM
m1943's Avatar
HTML Code:
Oil is a hot a controversial topic here, in Europe Mazda recommends synthetic Castrol, there is a whole buch of threads on this in this forum, apparently a lot of guys think synthetic is better, some stick to mineral, others say it doesn't matter... I went with the synthetic philosophy.
Old Mar 28, 2009 | 03:01 PM
m1943's Avatar
[quote=m1943;2939099]I am sure it will be fine but I use 5W-20 oil only not part synthetic, full synthetic or European formula if you just use regular oil what Mazda recommends then you should be fine.[/html]Oil is a hot a controversial topic here, in Europe Mazda recommends synthetic Castrol, there is a whole buch of threads on this in this forum, apparently a lot of guys think synthetic is better, some stick to mineral, others say it doesn't matter... I went with the synthetic philosophy.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 17, 2015 07:48 PM
