Semiazas
03-24-2009, 01:19 PM
Hey guys my headlight was brutally hit by a flying piece of trash on I95 while racing and it cracked it and water got inside over a couple 2 weeks or so. Today i removed the bumper and the light and fixed it and since it got water the headlight Low beam wouldn't:banghead: work. Once i cleaned it out and reinstalled it the light was turning on so i put the bumper back on and moved the car from driveway to street and now the light wont turn on anymore. Any possible fixes or anything i should look for im going to remove the light again tmrw and check all the connections bu everything looked fine upon removal.
Thanks in Advance.
Vyndictive
03-24-2009, 03:09 PM
hmmmmmm.... did you win.. . ?:eyetwitch
well, the light worked after you did your fix. But if the seals aren't good, that could be affecting the light, never having messed too much with my headlights for this reason I am not 100% on this.
But I would start with making sure all your wires are tight. Something may have slipped off when you putting the bumper back on.
Get a voltage/circuit tester and work your way back from the light.
mkztg
03-24-2009, 03:38 PM
Sounds like a loose wire somewhere - trust me - I had a loose wire in my throttle body sensor harness and it took forever to figure that one out. :banghead:
Start with checking the wire connections/harness
mkztg
Jedi54
03-24-2009, 03:40 PM
+1 to loose wire somewhere.
DOMINION
03-24-2009, 03:44 PM
If its cracked why not as the dealer to replace it? I would. Never hurts to ask.
Socket7
03-24-2009, 03:48 PM
I'm sure they cover all those racing related damages under warranty. Just tell them you were playing "2 fast 2 furious" :squint:
DOMINION
03-24-2009, 04:15 PM
Dont have to know you where racing, he could have been driving fast and killed a cat or hit a dear. Would they cover it then? IDK. Ask and find out.
carbonRX8
03-24-2009, 05:12 PM
A dear what? Dear grandma? You bastard!!
BANZ HIM!
Semiazas
03-28-2009, 12:50 PM
Ok update on the situation... I once again did the same procedure to check it but this time i opended the electrical box on the headlight you know the one that says 25000 volts Death Ahead sticker. Well anyways one of the blue cylinder thingys has rusted on a connections and ruined it now i need a new assembly as well as the headlight box electrical device.
