Need help, drive line shutter when Hot.
Old Mar 24, 2009 | 12:04 PM
Raptor75's Avatar
About a year ago I started to notice a shutter in the drive line after I drove the car for over an hour on the express way. It was only evident when I would put the car in reverse and engage the clutch. summer only. When it first happened I though something big had broke. It would happen all last summer when the car was hot.
It disappeared in the winter but I just did a 2 hour highway drive last weekend and it hit again. This time I noticed it in 1st gear also. It felt/sounded like the clutch was slipping then catching every fraction of a second for a few seconds. It was more prominent in reverse. Once the car cold off it went away.
At first I wasn't sure were it was coming from, but now I suspect the clutch. Any ideas here? The car has only 20K miles on it and does not display any other symptoms of clutch slippage, no burning smell, no slipping, etc... I've driven clutches for the last 30 years and never burnt one out. I'm at a lose as to what is wrong.
Old Mar 24, 2009 | 12:07 PM
kersh4w's Avatar
Hit & Run Magnet
did you buy the car used?
Old Mar 24, 2009 | 01:21 PM
Raptor75's Avatar
Nope, bought it new. It is a 05 GT 6spd, again first noticed this over a year ago, actually not last summer but the one before. When it first started to happen I thought it was something in the rear differential area. But as of this weekend I think it might be clutch related but am not sure.
Old Mar 24, 2009 | 01:37 PM
alienRX8's Avatar
Boosted!!!
I think I have that same shutter. It also happens when the car is hot and only when I am letting the clutch go to move the car either forward or backwards. I heard that it could be the LSD. But im not really sure.
Old Mar 24, 2009 | 01:48 PM
Raptor75's Avatar
I originally thought it could be that but the Torsen differential is a gear unit that has no clutch plates that I am aware of. I can't see what would be slipping or making the shutter.
Old Mar 24, 2009 | 07:01 PM
Old Rotor's Avatar
Motor mounts....
http://www.finishlineperformance.com...01-09-2062.pdf
Old Mar 24, 2009 | 09:07 PM
alienRX8's Avatar
Boosted!!!
my motor mounts are new and perfect, plus the shudder comes from the backend. And its not all the time.
Old Mar 25, 2009 | 09:13 AM
Raptor75's Avatar
Possibility but I don't think this is the issue. My 05 is a a late model year production outside the scope of the TSB. Also the description of this problem is different then what I reported and I have not experienced the symptoms that the bulletin describe.
Do you have any other information as to why you may think this is the problem?
Originally Posted by Old Rotor
Old Mar 25, 2009 | 09:15 AM
Raptor75's Avatar
I to thought the shutter was from my pack end. It is very bad when hot and I hit reverse quickly. What about yours?
Old Mar 25, 2009 | 09:40 AM
PPF has shifted?
Put it up and have them check the alignment on the PPF
Low on rear end fluid?
Old Mar 25, 2009 | 09:55 AM
alienRX8's Avatar
Boosted!!!
PPF??
it happens to me when going forward too but its almost never so idk.
Old Mar 25, 2009 | 03:17 PM
Raptor75's Avatar
How could the PPF shift? If it did would not there be an issue all the time rather then when the car is hot?
Originally Posted by Razz1
PPF has shifted?
Old Mar 26, 2009 | 02:12 AM
the mounts have been changed and the ppf has not been adjusted, bingo..
had this happen.. motor replaced from the top with new motor mounts..
master tech and i drove the car, shudder. i looked at him and said ppf. he was shocked that i knew what it was.
sure enough that was it..
Old Mar 26, 2009 | 05:13 AM
whitebeau's Avatar
Touge Chaser
Whats PPF Stand For? I searched online, and through the forum, i'm pretty sure it's not a Financial Institution definition.
Old Mar 26, 2009 | 05:20 AM
power plant frame. it is a very large beam that connects the rear diff to the back of the transmission..
Old Apr 1, 2009 | 10:39 AM
Raptor75's Avatar
I haven't changed motor mounts. The car was rear ended about 3 years ago, no metal damage but the jackass did destroyed the rear bumper and impact material. Could this have missaligned the PPF? Also if it is misaligned what actually causes the chattering noise?
Thanks in advance.
learningdriver
Aug 8, 2015 06:55 AM
arjunmshah
Aug 6, 2015 10:56 AM
Belalnabi
Jul 17, 2015 07:48 PM
