View Full Version : Humming sound when off
LionZoo
03-20-2009, 11:37 PM
I haven't had much time to post on here, but in the last few days I've noticed there's a slight humming sound from the car when it is off. The key is out of the ignition, but it sounds like there's still a very quiet electrical hum from the engine compartment. It's puzzling and I'm afraid it's going to discharge my battery so at home I've been hooking it to a trickle charger at all times.
myriadshalaks
03-21-2009, 12:08 AM
it's not the fan?
teknics
03-21-2009, 12:35 AM
guessing fans, and yes its normal.
kevin.
Razz1
03-21-2009, 01:02 AM
Does it sound like this.............hummmmmmmmmmmmmmmm.....?
swoope
03-21-2009, 01:07 AM
likely your interior lights slowly dimming..
yep they make a noise.
beers :beer:
ZumnRx8
03-21-2009, 02:24 AM
1. Fans, mine do it very rarely
2. Interior lights sometimes do.
zoom44
03-21-2009, 02:29 AM
there's also the evap test to perform every time you shut it off. a vacuum pump checking for leaks
sw-ontarioguy
03-21-2009, 02:58 AM
Have you listened to it for 5 or 10 mins to see if it stops? If it does, it'll be any of the previous suggestions. You could also not hook up your trickle charger, let the car sit over night (10-16 hours) see if your battery is ok. If she starts fine, you know it's nothing to wrry about :)
