want a DIY for chnagine out old engine for new one
Old Mar 20, 2009 | 11:02 AM
Hesselrode's Avatar
US Navy Rotary Enthusiast
can someone create a DIY for engine install i am installing a new engine soon and would like to have this when i go to do it... I have never done an engine swap, but would feel very comfortable doing an old 350 carb engine.. I have alot of experience just not doing engine swaps.. thanks in advance....
Old Mar 20, 2009 | 11:04 AM
dabax2324's Avatar
lol you shuold put a big *** super charger blower on it also
Old Mar 20, 2009 | 11:24 AM
Hesselrode's Avatar
actually i plan on it.. a 12lb boost procharger kit.. unless i change my mind and do a turbo just for the buuunn tiss... buuunnn tiss... sound lol
Old Mar 20, 2009 | 07:43 PM
teknics's Avatar
Certified Mazda Tech
the easiest way to think of it is like this.
look at the engine, picture a halo around it. Nothing should cross over this halo, anything that does needs to be removed and swung into the engine bay or onto the motor to be removed with it.
You could disassemble most of the intake to make it easier. I'll wait for someone else to chime-in tho as i remove all my motors on a lift so i can do it the easy way by dropping it with the whole subframe/front suspension lol.
kevin.
Old Mar 21, 2009 | 11:04 AM
olddragger's Avatar
most of us take it out the top. if you can do a v/8 swap you can do this. basic rules apply. label your lines/wires/coils etc. Getting the shop manual would also be a good idea--as the tq numbers on certain bolts etc will come in handy. Did mine in the backyard with 2 dogs for help.
olddragger
Old Mar 23, 2009 | 06:24 PM
Hesselrode's Avatar
doesn't mazda do it from the bottom? do they do this cause it is easier? if not why do they do this?
vapor2
Nov 3, 2020 03:38 PM
airlive
Nov 4, 2016 12:15 PM
robd1337
Jul 31, 2015 09:35 PM
madrotor
Jul 26, 2015 12:06 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
