Locked my only key in my car.....
Old Mar 16, 2009 | 12:42 PM
lVoiDl's Avatar
VoiD
Ok so today I was washing my 8 because it was a great day out. While I was wiping down the inside I accidentally locked the doors.......and then shut them. I walked around to do the other side and now both doors are locked.
Any ideas?
Old Mar 16, 2009 | 12:48 PM
Easy_E1's Avatar
Call AAA or a locksmith.
Old Mar 16, 2009 | 12:51 PM
SideOfBacon's Avatar
Skeleton Key. Menards/Lowes/Home Depot carry them. Think they are about a buck fifty.
Old Mar 16, 2009 | 12:59 PM
lVoiDl's Avatar
VoiD
just called a locksmith.....85 to get the keys out....
Old Mar 16, 2009 | 01:04 PM
04rx8gr's Avatar
Slim jim I have one if you were around here.
Old Mar 16, 2009 | 01:12 PM
lVoiDl's Avatar
VoiD
One of my friends is a cop just gave him a call, he says they can get it open for me for free.
Old Mar 16, 2009 | 01:22 PM
04rx8gr's Avatar
Good to hear
Old Mar 16, 2009 | 02:06 PM
Myardor's Avatar
That is the beauty of the SmartKey on the Shinkas, never get locked out,
BTW that 10 hole brick would do wonders on windows
Glad some one could help u.
Old Mar 16, 2009 | 02:11 PM
tubingchamp's Avatar
What mawd bug?
Slimjim doesn't work. I locked my key in my car while it was running once, had a local company come and try to open it. They needed to get a milk carton(so it doesn't scratch), put a little hand pump in it to pump the door open a bit, then use a hook-type-slimjim thinger. Took about 35 minutes :O
Old Mar 16, 2009 | 02:13 PM
laythor's Avatar
I zoom therefore I am.
brick vs window isn't 100% guarantee of breaking the window... better off using a spark plug.
+1000000 on the smart key.. zero chance of locking your keys in the car.
Old Mar 16, 2009 | 03:19 PM
Wind Dance's Avatar
Central Valley RX8
+1 on having spare keys
Old Mar 16, 2009 | 03:36 PM
04rx8gr's Avatar
It does work just gotta be quick at what you do It has an auto lock function so if its pulled then it instantly locks back and freezes the lock. . If you hit it and open the door a the same time then your golden
Old Mar 16, 2009 | 03:55 PM
lVoiDl's Avatar
VoiD
That is exactly what he brought pumped the door open and this hook think poped the lock from the inside!
.....NOW i have a new problem when i press the clutch to the floor it does not come back up all the way! So called the dealer going to bring it in Wednesday to get it looked at because i have no idea what it could be.
It comes back to a point then just stops and I have to pull it back the rest of the way.
Old Mar 16, 2009 | 03:56 PM
XlYesterdaYlX's Avatar
Zoom x 2
i <3 my smartkey.
Old Mar 16, 2009 | 04:00 PM
StealthTL's Avatar
Metatron
If your lock problem is fixed, open a new thread for your clutch prob.
S
Old Mar 16, 2009 | 04:01 PM
Atilla's Avatar
I am THAT guy
Use the brick...
You're already on a roll with locking the key inside the car
Old Mar 16, 2009 | 04:13 PM
CyberPitz's Avatar
Huge hole is huge
And this is why I have a spare key inside my house.
Old Mar 16, 2009 | 04:30 PM
ken-x8's Avatar
Did he reach for the lock button inside the car, or did he grab something inside the door?
Ken
Old Mar 16, 2009 | 06:15 PM
lVoiDl's Avatar
VoiD
Ken
Wedged the door open and undid the lock from inside the car never went in the door at all.
Old Mar 16, 2009 | 07:34 PM
Maffu313's Avatar
YAY =) go smart-keys =D
Old Mar 16, 2009 | 09:48 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Locked key in a rental car and AAA came out and put this rubber thing between door and door jamb and then put a wire thing in there and unlocked. Cars are easy to break into.
Old Mar 16, 2009 | 09:50 PM
Take your VIN and ID and go to the dealer..they can cut you a key...won't start the car without programming..but it will open the door
Old Mar 16, 2009 | 10:15 PM
Myardor's Avatar
TX
Car battery was low so i figured I would let the car run ie on and lock the door.
Since I have this SmartKey, I could just unlock it and get back it!
WRONG!
Car would not lock ie will not lock with engine running.
Old Mar 16, 2009 | 10:20 PM
Myardor's Avatar
TX
Oops yes should have put it in new thread
Old Oct 13, 2009 | 10:45 AM
Xander's Avatar
I did this today..mazda cut a valet key for $5.00
