Are rx8 suppose to shake ?
Old Mar 14, 2009 | 10:34 PM
zamp's Avatar
There is an rx8 im currently looking at buying. So anyways i went up there today and jumped in it. I noticed that when it is idling a tad under 1k and then you give it some gas it shakes some until it gets about 1.3 - 1.5k RPMS. Is this normal for a rotary engine? I made the comment to the dealer and he said that is how the rx8's are...
Old Mar 14, 2009 | 10:36 PM
hakuna matata!
flat out no.
most likely 1 or both of the motor mounts are bad.
have them fix it.
Old Mar 14, 2009 | 10:41 PM
zamp's Avatar
Originally Posted by alz0rz
flat out no.
have them fix it.
How much do you think that will cost?
What do you mean by shake?
Are you talking about the shifter? That is normal.
Old Mar 14, 2009 | 10:45 PM
zamp's Avatar
Yah the shifter shakes as well as the car. But it only happens when its under 1k RMP. When driving the car was not shaking or anything like that.
Old Mar 14, 2009 | 10:47 PM
shazy's Avatar
Well it depends, but just get the motor mount checked. It also depends on how you drove it, if it high rpm the car is shaking that could mean the motor mount.
Well you say under 1k rpm, check the plugs and have them replace the ignition coils and wires. That should solve the problem
Old Mar 14, 2009 | 10:49 PM
zamp's Avatar
Yah it only really shakes when its from about .8k to 1.3k... other than that it drives smooth. I am going to have a mazda dealer ship run a check on everything before i buy it.
Im getting it for 10,000 :D 04 48000 miles
Old Mar 14, 2009 | 11:08 PM
WTBRotary!'s Avatar
Drummond Built
I have a auto and my car shudders as well but its normal, my motor mounts are fine... now if you have excessive shaking then obviously its a motor mount. I do not think its the coils, plugs and wires...
Old Mar 15, 2009 | 09:40 PM
dondo's Avatar
100% baller (finally!)
maybe he's just talking about a rough idle though? if you're getting it from a mazda dealer then have them take a look for you.
Old Mar 15, 2009 | 10:45 PM
mlfarrell's Avatar
i get a very slight shutter at low rpms in high gears. I generally regard it as normal
Old Mar 15, 2009 | 10:53 PM
zamp's Avatar
It is when its in neutral and you rev it up.
Old Mar 15, 2009 | 10:57 PM
kellyrx8's Avatar
mine has a vibration when i put it in reverse...i think i may take mine in and get the motor mounts replaced...
Thanks for the tips guys
Old Mar 15, 2009 | 11:00 PM
mlfarrell's Avatar
oh wow. Yea I'm AT so your problem is totally different.
Old Mar 15, 2009 | 11:05 PM
zamp's Avatar
So any idea what it would be ? It happens in 1st and neutral that i have noticed...
Old Mar 16, 2009 | 10:38 PM
JDM's Avatar
JDM
My car shakes as well under 1000 rpm, above that, its smooth as butter. The car has been like that ever since ive owned it, and its been to mazda a few times. I assumed it was normal.
Old Mar 16, 2009 | 11:32 PM
myriadshalaks's Avatar
rot8ing
could be it doesn't have the latest reflash, tsb 13, i think, which is meant to address just this problem, i think.
otherwise motor mounts sounds like a good answer.
Old Mar 16, 2009 | 11:38 PM
shazy's Avatar
Yeah just go to the mazda dealership and make sure you have all the latest Updates for the car.
Old Mar 17, 2009 | 01:21 PM
rx8mod83's Avatar
Lifting Rx8 Society
Sounds like a motor mount issue i replaced them all when i purchased my rx-8 and now it does not shake at all.. i did have minor tremors though prior.
Old Mar 17, 2009 | 01:37 PM
Socket7's Avatar
ಠ_ಠ
The shifter should purr in your hand. The car itself should not vibrate.
Old Mar 17, 2009 | 03:41 PM
Rems31's Avatar
shouldn't it shake when you bog the engine?
Old Mar 17, 2009 | 04:19 PM
rot8ing
good point. the engine idles at 1k, who the hell starts going at 1.5k?
Old Mar 17, 2009 | 04:31 PM
rotaryspitfire's Avatar
Jacksonville, NC
The only time I feel any vibration is around 127 MPH. The rotary engine has 3 major moving parts and should run as smooth as anything you have ever sat in or on.
Old Mar 17, 2009 | 04:36 PM
Jacksonville, NC
And, avoid the 2004 model year. Stick to 2005 and up. $10k is a good price but spend a little more and get a car that Mazda has had time to work out the bugs with.
Any car is bad news when there is a thread about how many engines you have had replaced, mostly the 2004 model
