SSV Acuator D:?
Old Mar 5, 2009 | 11:23 AM
Ryoma-kun's Avatar
SSV Acuator D:?
I have a huge problem. I went to my dealer because I've been hearing some 'ticking' noises from my engine when it's idling. No power-loss or any other problems. The dealer call me some hours after I delivered the car and told me the Actuator was broken and the entire manifold would have to be replaced. They told me that they would charge me no less than 2800 USD for only the part! God knows how much they would charge me for the work. They told me that leaving it like it's now would do no harm whatsoever except that the ticking noise would be there. Now to the real problem, a month or so ago I installed a K&N Typhoon Ver 2 Intake. They're of course blaming the intake to have caused more worn on the broken part than it would normally have and they won't do it under warranty because of this. I have a 2005 192 HP manual (european) with 30 000 KM on it. I asked for the part number for the Actuator thing: N3H4 13 100K
Old Mar 5, 2009 | 01:20 PM
Ryoma-kun's Avatar
Please anyone? :/
Old Mar 5, 2009 | 01:27 PM
G3tR3DDY2GR3DDY's Avatar
hey buddy, i have a complete lower intake manifold that i could send you... if you have any experience mechanically, you can swap them out. Or hell, just pay someone to do it for you.. you would save over 3k im sure.
PM me
Old Mar 5, 2009 | 01:32 PM
Easy_E1's Avatar
If it's a 6 port the engine will have to come out to remove the LIM. Sad but true.
And really the K&N is not going to cause extra wear on this. Amazing.
Old Mar 5, 2009 | 01:36 PM
Ryoma-kun's Avatar
Greddy: If that's the part I need I would really really love to buy it from you. I'm so frustrated now because I don't really know what I should do. I can't afford 3k USD + 10 hours work +
The 192 HP is a 4 port right? I believe the AT and European 5-speed MT is quite similar.
Old Mar 5, 2009 | 01:37 PM
Easy_E1's Avatar
AZ
If it's a 4 port it can be done with the engine still installed.
Old Mar 5, 2009 | 01:40 PM
Ryoma-kun's Avatar
Hm ok that sounds good. I still have no idea how to change it but I'll do some more research tomorrow and get another dealer to look at it so I'm sure that it's really the manifold that needs replacement.
Old Mar 5, 2009 | 01:43 PM
jmc23200's Avatar
Ask Mazda to produce a technical document stating the installation of an aftermarket Intake will cause damage to the actuator and/or manifold. I bet they can't provide you with any documentation and its only there opinion lol. They are going to try and rip you off, thats the stealership way. Theres a ton of great members here that can try and help you out. Im sure someone can supply the workshop manual thread link to get you on your way once you get the part.
Old Mar 5, 2009 | 01:48 PM
hmm the manifold i have is for 6port.. easy you know if its the same? i am for some reason thinking just the UIM are different but i guess not...
Old Mar 5, 2009 | 02:00 PM
Easy_E1's Avatar
AZ
Lower are different too.
I have found that the 5 speed is a four port engine. Why does the dealer feel that you need an entire manifold? The Actuator is vacuum fed. And it's the same as the six ports.
I just took this picture and this is what it consists of. I can be removed and replaced without taking the manifold off.
What makes them think its broken? What is broken?
First pic shows tthe mounting point. It's held in by the two 10mm bolts.
Second pic is what looks like in relation to the manifold.
This is a 6 port LIM. But the SSV is the same.
remove the two 10mm bolts and it will slide out.
Attached Thumbnails SSV Acuator D:?-ssv-6-port.jpg   SSV Acuator D:?-ssv-6-port.j01.jpg
Old Mar 5, 2009 | 02:04 PM
jmc23200's Avatar
Now that I see the picture, I can see how an intake would cause damge Gotta love dealerships.
Old Mar 5, 2009 | 02:10 PM
Ryoma-kun's Avatar
I'll call them tomorrow and ask for more details.
Old Mar 5, 2009 | 02:11 PM
Easy_E1's Avatar
My opinion is that it is just sticky and needs to be cleaned. A can of Brake Clean will do wonders if you remove the Upper Intake Manifold and spray the crap out of the SSV valve itself. Rotating it by hand while spraying. Its the copper colored piece in the engine side of the intake ports.
Old Mar 6, 2009 | 08:31 AM
Ryoma-kun's Avatar
Called them today. He told me the reason but I don't know the english terms for anything related to this. He said some 'thing' was 'worn' and was not working properly and the part was not sold seperately so only option would be to replace the whole manifold. I'm going to put my stock intake back in this weekend and deliver it to another Mazda dealer on Monday. I'll see if they'll treat me better and if they have a different solution to the problem.
Old Mar 6, 2009 | 09:50 AM
The SSV can easily be removed..and cleaned...it is really unlikely that it is worn...unless you have 500000Km on the car.
If you are mechanical at all it is an easy thing to fix...
If the actuator is broken...I'm sure Patrick or someone can get you a spare.....you don't need a whole LIM....
Dealers are such douches sometimes
Old Mar 6, 2009 | 10:26 AM
Remember ... he stated the dealer said it is fine and won't affect performance. Just makes noise.
Old Mar 6, 2009 | 11:55 AM
^^ That in itself is crap
If it's broken..it will effect performance andif it works..it won't.
If it is working..then what is the problem
Old Mar 6, 2009 | 12:11 PM
teknics's Avatar
Certified Mazda Tech
the dealer wants to make money off you and so does the tech. mazda's warranty time for both 4 and 6 port motor's includes engine removal for lower intake manifold installation. Tech's no on 4ports they can do it with the motor in the car but no one wants to pass up 10+ hrs of cash labor, and the manifold costs you a pretty penny too. Whereas the SSV replacement costs like 3hrs max of labor and a couple hundred for the valve.
highway robbery.
printout and show them the TSB with the p2070 code, ask why you can get the valve seperate for the TSB but they magically cant for your car.
kevin.
Old Mar 6, 2009 | 02:25 PM
Ryoma-kun's Avatar
I'm taking the 8 to another dealer on Monday. Hopefully they'll find a better solution for this. I'll update once I know something
Old Mar 6, 2009 | 08:13 PM
DOMINION's Avatar
I don't buy Kool-Aid
Ahh snap! Looks like I found my ticking noise. Dam it. Time to clean that bad boy or see if its broken. There gos my Saturday
Good read thanks for the info guys.
Old Mar 7, 2009 | 03:48 AM
Ryoma-kun's Avatar
Give an update whenever you've located your problem :/
Old Mar 11, 2009 | 10:45 PM
DOMINION's Avatar
Well I did the seaform. It did not go away but it got realy quite. But now its back. Dam it. Guess its time to see the dealer. All I know is this sound is not normal. I'm the only 8 thats doing this out of all my friends 8's.
Willopap
Oct 29, 2015 11:04 AM
Evan Gray
Sep 26, 2015 12:30 PM
jtdwab
Sep 12, 2015 04:57 PM
tgaffner
Sep 7, 2015 08:49 PM
